1 - 20 of 25 Posts
Probably don't have it around the house but I like Plexus. It's made for such things. Pick up a spray can at your dealer.
yeah i've heard of plexus, i hear its good on all the plastic parts on a bike. on the other hand windex does seem to work pretty good, i have even used it on my leather jacket and it takes bug guts off really easily.
Using an old Windex bottle I filled it with one drop dishwashing soap and water. Spray after a ride and wipe off and its good as new. No need to bother with the chemicals.
I use windex all the time. Honda cleaner works well too.
windex works, as stated above, spray wax works pretty good to with a micro fiber rag. I used that for a long time
What I do is when my helmet or bike is dirty I clean is with soapy water then I wipe it down lightly with a cloth wet with rubbing alcohol and then apply a coat of RainX. For a good month everything including bugs, grease, or tar comes off very easy with soapy water and it is a great protectant otherwise and if you end up riding in the rain the water sheets right off of your visor. Also RainX makes a product for anti-fog that I put on the inside of my visor and my motocross goggles and it works wonders against fogging up. just my $0.02.....:cheers:
using windex to clean your visor is a bad idea! windex is ammonium-based which WILL make your visor opaque over time! soapy water is more than enough to clean a visor!
they use ammonia for fragrance! ammonia will cause visors to get an opaque quality, makes it cloudy after several uses!
From the Windex site:
... Can I use Windex® on all types of windows and mirrors?
On glass windows, mirrors, and Plexiglas®, Windex® cleaners work great. They're fast and easy, and they cut right through dirt and grime. Just spray on Windex® and wipe it off for a streak-free shine.
If you plan to use Windex® on your tinted windows, test a small area first. Care of tinted windows may vary.
For all of you airplane and helicopter owners, we're sorry, but Windex® is not formulated to clean your LEXAN® windows." ...
I use Dish soap, S10, or Honda spray cleaner and a micro fiber or soft cloth to clean my wind shields/screens/bike, works fine for me. I remember hearing a long time ago that ammonia was not good for plastics as r3yrey said.
Super Moderator
Benn using predominently Windex for my whle time riding. I use a helmet for two to three years before I stop using them, and the faceshield I start with is the one on the helmet when I'm done. Never noticed any discoloration or anything.
so i guess it depends on how often you put windex on the visor and how much... cause i was told by one of the reps from vega helmets that ammonia can cause cloudiness or make the visor "opaque".
anyhow, if its one of those $99 helmet i probbly wont care, but for the $400 one, I wont take my chance.... scratch that... visors can easily be replaced! so i guess its no problem
Super Moderator
I don't know honestly :dunno: I am in NC and end up with bugs and junk on my shield every ride. So I'm cleaning my shield after every ride.
I've used Plexxus on occasion, and really liked it. I think they even make a small can, so I may have to look for it.
lol.. i live in AL and i go to Mt.Cheaha every weekend to ride the twisties and i swear, it feels like i'm hitting every bug from my house to the mt. and back! so yeah me too, i clean my bike and my helmet pretty often. I guess i'l try using windex or plexus on my visor/shield. I do know that they have alcohol on them so i guess that helps with fogging too!
R3yray, how long do you expect your visors to last? I use windex all the time, and replace my visors once a year because of scratches, not because they are chemically damaged.
You shouldnt keep your helmet for more than 5 years, and I have serious doubts you will see signs of chemical damage to your visor during that time. When its a high priced item like a airplane window, I understand the precations, but on a $35 visor?
Hell, even with a fancy $70 one, I think you will spend more on a fancy cleaner than a replacement shield.
lol i see! i wouldnt worry about it too much then! thnks
btw.. i didnt know youre suppiose to get new helmets every 5 years? ever with no incidents? not even dropping the helmet to the ground?
anyway... I'm new to motorcycling...:eek: i learn something everyday i'm on this forums... thanks for the advice!
Super Moderator
Yeah bro... the reaction from your sweat on the materials in the lining of the helmet breaks down the materials. I sweat a lot, and I'm in NC, plus, I tend to put a LOT of effort into my riding at times. So I change out every two years or so.
It's amazing. Try a new helmet of the same make and size after you have worn yours for a while, and you will see and hear the difference. :thumbs2:
Super Moderator
mac020 said:
Also the shell continues to harden untill it becomes brittle.
I've heard about that, but never any substantiation on whether it's UV, chemical, or otherwise.
Where did you hear about that? I'd love to read/hear more because I've asked about it and never got any straight answers
1 - 20 of 25 Posts
