In some videos I watch, I see people only pulling the clutch in with 1 or 2 fingers. while the rest is under the clutch onto the bar. is there a purpose for that? or is that just how some people ride? I would think if you did that, you could squish/crush your fingers between the bar and clutch lever. wouldnt that hurt heh?
its prob for cumfort and also so that they can keep hold of bars when rideing pritty fast
also u sould not crush fingers as onces u get used to useing ur clouch sameas in a car u will know how far to pull untill it disengages so u dont have to pull it fully to the bars for it to disengade so means for faster gear changes and jsut easyer rideing
All I have ever used is two fingers for the clutch & front brake levers, bar back in '46 till '54 with heavy to operate clutch & days of drum brakes. No need for all four fingers to pull in the clutch or brake levers.
No reason in particular. I do it for convenience and comfort. I do the same with the brake lever.
nice
after reading this thread about a week ago I've tried riding that way. I feel more in control because I don't have to fumble around the handle bars. Plus, my hand position is adusted so it keeps me aware of how much (or little) gas I really need to give the ol' girl.
clutches can be set up for easy pull, and depending on your preference, it's no biggy to even pull with 1 finger all day long. I prefer to pull with three because it happens naturally, using 2 fingers might require little more attention. I use two to pull, and third one for leverage or no use. and all of this is even easier because you only pull in the clutch for 1/4 of the travel to shift, rest of it isn't necessary and waste of time. for brake, i use 2 fingers and sometimes 1.
sounds good
but I'm not up to the level or confidence to start adjusting my bike yet. I'm still getting used to the set up I got. A friend of mine who rides and fixes em' is comming over this weekend so I may get him to show me. I'll keep your advice in mind though...thanks!
I have never adjusted a darn thing on most of my bikes almost since '70s bar a minor thing or angle for especially my left ankle cannot handle a regular gear change lever position. True back in the late 40s & late 60s we really suffered.
When it came to bikes I was to test for a m/c mag (that was from sometime in the 50s to mid '70s) I left the control levers 100% stock, bar the gear change lever as mentioned above, & would put a month or so on each bike.
Also as a m/c dealer/mechanic I accepted the way the customer had the foot & hand controls. My one advantage is I have long hands & fingers ,so Ex-Large in gloves, though not powerful ones & in the latter I work with strengthing up my hands & fingers.
Like to-day was a short run, of five hrs, to me due to this being a long week-end from Saturday till end of Monday, & I stay clear of them, though bar Sunday I have been riding basically the last three weeks around 5 to 7 hrs each day in these mtn roads. My hands & body are not tired yet I am 75 yrs of age with this being my 59th year of riding.
