1 - 20 of 45 Posts
Please share some experience here.
With non-perfed leathers (providing a very GOOD wind barrier) and long johns, what is the lowest temp you have found them comfortable for several hours of riding?
I am looking for a solution to about a 45-50 degree problem. That's about as low as I will see in Savannah (that I want to ride in anyway.) It gets colder, but not so often that I have to be suicidal about riding in it ;) .
I have been "making do" with various non-bike gear, but I want to move up. My Goretex "field jacket" keeps me warm, but beats me to death on the arms with flapping, and the "coat-length" bunches up at the crotch. Flapping is bad with every other textile coat I have. Same with some light nylon over-pants. On top of that, none of these give much protection from a spill.
I have my eye on a used set of non-vented leathers that should permit room for long-johns (about $300). I'm guessing that this combo would work pretty good, but buying them is the only way I can find out, unless you help. :)
Yes, I know the Aerostitch Roadcrafter would be perfect. But, I am just not quite ready to pop for the $800-$900 yet. Generally, I try to make several inappropriate purchases first to save money. After wasting several hundred $, I go back and and buy the right thing. :rolleyes:
1. the leathers -n- long johns should do fine for 45-50deg
youre prof says fleet management , like gsa fleet?
Secasarge, Fleet = local county government fleet (i.e. some of everything; dozers, ambulances, police cars, road graders, etc, etc, etc).
oh cause i do GSA fleet management for the military org. im in
i.e. cars vans etc..
also you suck 45 - 50 degrees? god i ride with my jacket- n- jeans
in that weather! here it has not gotten above 32 degrees since
dec15th.
Based on experience (but I'm a bit cold natured), I think you'll do fine with a layer or two under your leathers. Fingers might be the only problem on longer rides.
One thing to consider is how smooth the layer next to your skin is. Way back, I once wore long johns (typical rough weave) and went down one November (cold tires). I had on a light, nylon Addidas jacket, which didn't have a scratch on it! Unfortunately, my left forearm (which hit first) got a case of road rash, apparently from the movement/burn caused by the shift in the long johns. My arm hurt like the dickens, but I figured it was just bruised since the outerwear didn't have a scratch. Imagine my surprise when I got home and peeled the jacket off... :eek:
Anywho...you might want to try some bicycle shops in your area. I used to do a bit of bicycle road racing, and a lot of the stuff designed for bicyclists transfers well to motorcycling. You can also try Sierra Trading Post, as they have great prices on all kinds of gear. I've bought a lot of closeouts/seconds, etc from 'em over the years.
http://www.sierratradingpost.com/
http://www.performancebike.com/
http://www.nashbar.com/index.cfm
To carry it one step further, consider an electric vest (I've got a Widder collarless). Got the collarless unit since it packs small, and I always have it in my Concours. I haven't used it on the 6R yet, but I have a hookup on it (also doubles as my Battery Tender hookup). If you're out leather shopping, you could buy a jacket with a removable liner, remove the liner, and use the vest instead if temps require. I bought the Kawasaki jacket which matches the bike's paint scheme. List is around $400, but Ron Ayers sold it for $300. They won't take exchanges without a restocking fee (on special orders), so I got Competition Accessories to price match, and ordered from them.
Leathers & long johns alone are easily good to 40 deg.....I ride in that that range just wearing leather jacket, thermal underwear shirt & leather pants.
OK and thanks. I just ordered the used leathers from the Leather Exchange. Delivery is expected Monday and testing will follow immediately. :)
You should be good to go with leathers and long johns. Suggestions:
1. Get good gloves
2. Get good boots.
3. (this may sound dumb) Use a neckerchief or bandanna around your neck to keep cold air out. It keeps it from coming into the neck of your leathers and from going up into your helmet and turning your ears into ice.
‘Course, you could get some of those nifty, comfortable Land’s End turtlenecks! They’re well made, very reasonable, and have a long neck, which can be unfolded up over your mouth/nose in a pinch. Any time the weather allows (and sometime when it doesn’t), I ride with my turtlenecks. Weather aside, the turtleneck keeps my leathers from chafing my neck.
They’re only $17.50 each, & come in 100% cotton or 60/40 blend-my favorite, as they feel softer than 100% cotton.
Lands End Turtlenecks
http://www.landsend.com/cd/fp/prod/0,2503,1_2_1931_29843_10837_10221_5:view=59,00.html?sid=1010017522670&mode=GRAPHIC&refer=/cd/frontdoor/&fromsearch=1
I tried to generate enough interest to see ‘bout having the Sportbike World logo embroidered on the neck, but no one seems real interested, and I’m off to other things.
http://www.sportbikeworld.com/forums/showthread.php?s=&threadid=14948
Basicblur: Even better are than turttle necks are those spandex tubes called "neck gaiters". You pull it on over your head, as a separate turtle neck. Leave the top up over your chin and the bottom of it goes into your jacket. That pretty well cuts off the wind in that area. It is some better than cotton/wool because it blocks the wind better (cotton/wool leak air pretty bad).
GABandit12: I have the boots (Sidi Stradas) and they do fine. You are right about gloves though. Hands are the weak link without special attention. The Teknic gloves I have do about as well as leather gloves can, though.
Paul748S said:
Testing? Are you planning a controlled crash? I look forward to hearing the results.
Hey Paul,
I think testing he is referring to is
"temperature testing" as the post was about..:p
Discussion Starter #13
Thanks Cam. I think you said that about as nicely as anyone could. :D
I gots plenty of balaclavas (silk & thicker), an Apple Warmer, and NOJ Quiet Rider Deluxe. Hey, ya rides a sport tourer, ya gotta be ready for everything mother nature throws at ya, unlike some of these fair weather sportbike wimps in here! :D
Remind me to tell ya 'bout taking the Lighthouse Tour 'round Nova Scotia during Hurricane Hugo... :eek:
I've found the turtlenecks are one of the most versatile bits of clothing in my motorcycling wardrobe, even if certain Ducati riders in here call me a yuppie for wearing 'em! Hmmmm...a Ducati rider calling me a yuppie...well isn't that just special! I didn't have the heart (OK, I just didn't have the patience/time) to tell him Kawasakis typically aren't the choice of yuppies!
Now Ducatis...well, as usual, sometimes they're the last to know! :rolleyes:
Not a problem....I do have my moments...lol:D
Paul748S said:
I guess you've been to Arkansas with Pete?
Are you kidding....He's WAY too jealous.!!!:D
P
Guest
For an added level of wind protection and warmth, I highly recommend RS Taichi's Windstopper one-peice under-suit garment. I got mine from Kneedragger's.com.
Pete said:
Ha-phucking-ha.
Kind of like a Drive-by slam.....totally inocent,
minding your own business& just got sucked in...:D
1 - 20 of 45 Posts
