Which transition is easiest?
  • Inline-Four to V-Twin.
    Votes: 10 52.6%
  • V-Twin to Inline-Four.
    Votes: 6 31.6%
  • There's not much difference.
    Votes: 3 15.8%
  • Total voters
    19
I need help settling a heated debate... Do you think that it's easier making the transition from an Inline-Four to a V-Twin or from a V-Twin to an Inline-Four? (This question only applies to sportbikes.)
I thought this was a fairly innocent question so I brought it up last night while I was out at the bar w/ some buddies. About 5 minutes later we had half the guys in the bar arguing with eachother.
What do you think???
:confused:
I agree with RCjohn
you have to keep momentum better with a 4 and think about shifts more. Twins you just put it in gear and go.
I liken it to changing from a 2-stroke motocross bike to a 500 4-stroke single. The 2-stroke is a little faster but it's harder to keep on boil, while the 500 all you have to worry about is dialing the right amount of twist with your right hand.;)
Which inline four and which V-twin?
I don't think there's anything inherent in the engine configurations that makes one or the other more difficult to ride. However, examples of each can exhibit vastly different torque characteristics, and that's the interesting question to me.
I find that 600 fours (talking about the four Japanese sportbikes here) require the most attention. Let revs drop below 7K or so, and torque falls off into an abyss. An unsuspecting rider who's not watching the tach might find himself without the power to get out of a jam.
Liter fours, OTOH, are wonderful. The 929, for example, has bags of torque from 4K, and even below that. I haven't ridden an R1, 9R, or GSXR1K, but on paper they seem just as good.
Twins, likewise, vary considerably. The Hawk GT, SV650, and air-cooled Ducati 750s produce torque similarly to the liter fours (though, obviously, not nearly as much)--over a nice, even band that extends into the low end of the rev range.
Though I haven't ridden one of the Superbike twins (RC51, 916/996/998, Mille R), they seem much less user-friendly than the all-around twins. The torque curves peak high in the rev range and fall off considerably if revs drop below 5K. The Motorcyclist "Hard numbers" page reveals that these supposedly "torquey" motors don't even match the 600s in a 60-80 roll-on (e.g., 4.12 for the F4i, 4.94 for the RC51).
DataDan,
The information you've posted regarding the 60-80 roll-on times of the F4i versus the RC51 raises a new question...
1) Can't one make the argument that the gearing on an F4i, which makes considerably less torque than an RC51, may perhaps allow a slightly quicker roll on from 60-80mph without downshift because of the point in the torque curve the F4i is at versus the RC51? Basically, if the F4i is at 9k rpm and the RC51 is at 4k rpm while traveling 60mph the F4i may be within the optimal portion of its torque curve, while the RC51 may be at the bottom end of its torque curve? (note: I used the 9kRPM and 4kRPM numbers purely for conversation's sake. I do not know them to be accurate)
John,
I'd like to hear what you have to say regarding this comparison 'cause, coincidentally enough, I'm considering making the jump from an F4i to a 2002 RC51.
Thanks,
Dan
Good point. If the RC51 is "overgeared" compared to the F4i, that alone would put it at a disadvantage. I don't know whether that's true or not, though, because I don't know what the gearing really is.
But from info available, we can make a cocktail-napkin calculation. The RC51 has a top speed of 165mph and the F4i 155 (MCN). Assuming optimal gearing (top speed = power peak), the 60-80 roll-on would take the RC51 from 36% of peak power revs to 48% and the F4i from 39% to 52%.
Checking the dyno charts, that range corresponds on the RC51 to a range from 42% to 56% of peak torque revs and on the F41 from 48% to 63%. Part of that difference is due to the assumed taller gearing for the RC51 and part to the fact that the F4i has a slightly less peaky torque peak. The 600's maximum torque hits at 18% below maximum power while the twin's is at 14% below maximum power.
If anyone has real data (e.g., mph/1000RPM for the two bikes), we could find a more definitive answer.
Your "cocktail napkin calculations" could explain the .8 second difference in the roll-on times of the 2 bikes. However, as you said, "real data" would definitely enable "a more definitive answer."
I'm curious to see the 80-100 roll-on times of the 2 bikes. Do you have that data?
