Has anyone ever used one of the enclosed Uhaul trailers to take a bike long distance? There aren't any floor tie downs or a front wheel stop, so I am not sure what to do. I was hoping to get an open trailer, but those are only local. Any ideas on how to properly secure the bike? Also, is a 4x8 big enough? Thank you.
I helped a friend move from Tampa to Phoenix and we used an enclosed U-haul trailer for his bike and the rest of his junk...
We wedged the bike towards the forward corner... the corner acted like a wheel chock. We used the tie-down extenders as achors because the cam straps hooks doesnt fit through the holes of the wood railing. Use the rachet tie-downs as well because the cam buckles tend to losen up because of all the shaking when traveling. Use as many tie-downs as you can to distribute the load on the straps!
Also, use the kick stand to have at least 3 point of contact to the floor.
It's doable.
When I moved from VA to FL I had my bike in the back of a Uhaul with the rest of my stuff. Bigger truck, 17 foot or something. Had the wood slats that were raised off of the metal wall of the truck. I just took my tiedowns and looped one end through the little gap, hooking it onto itself. The other end of the tiedowns were attached to the bike's frame. One strap on each corner of the bike. Straps were used to keep the bike from swaying side to side. Left it in gear to prevent rolling back and forth with stuff jammed against the tires to help reduce front to back motion. Also, covered the bike in blankets to prevent an oopsy.
Like slowrat, side stand is always down when I trailer a bike, even if if doesn't touch the ground.
Zero problems. And you should see the way I drive. Even in a Uhaul.
I can help you with this one!!!!A 4x8 isn't big enough...You need a 5x8, but make sure BEFORE you rent it that it has the d ruings in the floor on the front corners...I've rented about 5 of them, and it works just fine...My bike was a real "trailer queen", when I first got it...HAHAHAHAHAH I ended up buying one of the kartworld trailers and absolutely LOVE it to bits!!!...But with the krtworld trailer, you CAN'T put 2 bikes on unless you fabricate side rails..the trailer isn't W I D E enough to tie down two bikes...but it is absolutely rock solid with one bike...I used it to tow my bike to Laconia NH from Allentown PA at 90mph and NEVER had to worry...It pulls really easy too...I still got 22mpg with the bike and a van full of crap....With the uhaul 5x8 I can only get 14mpg....damn wind resistance!!>>>>get yourself some some good tie downs !!!!Have fun!!!Jimmy G
Thanks guys. That gives me some ideas.
Jimmy... why wasn't the 4x8 big enough? Some people have said it's fine.
it was cramped with the bike and me while I was trying to lash it down....I rented sooooo many uhauls I used to just pick it up and leave a note...became good friends with the owner....remember in a closed trailer, you have to crouch down and connect the straps to the d rings in the corners....very tight...it will fit though, just that extra foot makes a world of difference...good luck.
P
Guest
You'll be thankful for that extra foot of room when trying to squeeze in beside your bike.
bigger trailer gives you more room to work with... and got room for the dead hookers...
