1 - 17 of 17 Posts
I was about to rotate my tires so that they wear evenly. There's only 2, so I would imagine they just go front to back. My question is do i need to turn them around, or are they directional. Just trying to get max tire life. Thanks.
One does NOT rotate their m/c tyres. You are still thinking like a cage driver with four wheels of the same width & all. Note that the rear is broader then the front & there is a reason in that like trying to keep you upright while riding.
Naturally you cannot reverse the direction of tha pattern of the tyres for then they would be backwards & again those patterns & what direction is most important in how they are put on the bike to help keep you upright.
You will probably need to replace the rear tyre quite a bit sooner then the front only depending upon how you ride it will not be to long before the front will need to be replaced.
and to add, most bikes have smaller front tires than rear.
I'm pretty sure you guys are mistaken.
unless your bike has "special" tires and a special setup, we're not. i don't know of ANY bike that you can rotate your tires on becuase as smitty already stated, the tires and tread are designed to only be rotated in one direction. AND like i said, they are two different sizes.
or are you speaking about something OTHER than your motorcycle?
Jerking your chain!
C'mon Smitty and Monkey- can't ya see Tippman's jacking with you guys!?!
He's talkin' about the Huffy.:cool: Good idea to rotate them. If you've got any bald spots, just wrap cloth electrical tape around the wheel, between the spokes, to extend the wear.:thumb:
Re: Jerking your chain!
becuase its tippman, its always hard to tell if he's serious or not. :laughing:
beleive it or not i once put duct tape on the treads of my sisters huffy....i thought she would have lowsided..but naw
S370HSSV 0773H
I can't believe nobody called :bs: on this until the 6th post! Tippmann is special, but he's not stupid (probably the nicest thing I've said about him :D).
He was screwing with you all....unless I give him more credit than he deserves.....:huh:
S370HSSV 0773H
Ok, so a serious questions about tires: why is the front smaller than the rear? Would you not get better grip with a bigger one? It would seem that it would certainly make it steer slower, but is that the only reason? I'm just curious as to why they are not matched front and back, or at least within one or two sizes (180 rear w/ 170 or 160 front, etc.). Anyone know?
maybe it might be that when turning the throttle is usaully on so therefore the weight gets transferred to the rear tyre where then makes the front lighter there fore not as much contact is needed to keep the front undercontroll?? its a hypothesis
That's pretty much it. The front isn't doing nearly the work of the rear when pulling through a corner. Cornering traction, accelleration, and increased weight from the transfer of the accelleration. That's further evidenced by the wear that occurs at the rear.
Discussion Starter #14
:D :twofinger :D
So true for when you turn up the wick fast the bike sinks to the rear & that broader tyre gives traction or will spin out. Reason for the broader r/tyre & same when in cornering.
The front gets more work then in the old days of most being "rear brake end artists" as WE know 80% of more of the stopping power is with the use of the front brakes & f/tyre & WHY a front tyre can become lippy or scalloped is due to heavy use of the front brakes.
For around a year I rode my firs bike being an old '36 Harley 45 flat head & only used the rear brake pedal for there was no brake lever or cable on the front. NOT that single cam break drums were much in those days. Fortunately I spent most of that first year in the bushes/trees & so dirt riding. Talk to a dirt rider & you will find they use the rear brake far more then a street rider.
Fact is I keep on amazing myself in that when it comes to brake pads needing to be replace I find the rear pads are the ones-----------due to so many yrs of dirt comp & NO I have never locked up a rear wheel when I had to stop quickly---did it once on a Yamaha TZR-250 FORGETTING that is what I was riding & not my Yamaha FZ-750 that required more muscle when haulting quickly, so I was sent over the bars of my TZR-250.
Resident Smart Ass!
Discussion Starter #17
:laughing:
1 - 17 of 17 Posts
