anyone know tire pressure f/r for a 96 zx6r. i have no manual, but it is on the way. just got it and dont want to ride if tires arent right.
96zx6r said:anyone know tire pressure f/r for a 96 zx6r. i have no manual, but it is on the way. just got it and dont want to ride if tires arent right.
Do NOT go by tire sidewall pressure. That is simply the maximum pressure for that tire and has nothing to do with your bike. If you use those tire pressures on the sidewall you will have no traction what so ever. I know, I made that mistake in my younger years and I have a limp every morning to remind myself of it. From brand to brand the tire pressure should vary that much as long as the tires are the same as the stock size. I find that with D207s, 32 psi front and rear gives a good blend between grip and wear. I ride a little hard so those pressures go up with temperature as I get the tires hot. If you don't ride hard all the time then I would run a little bit higher pressure (34 psi) for longer trend life. The recomended pressure for the stock tires on your bike should be on a sticker on the frame and possibly the swingarm or perhaps under the seat and of course in the manual. Those pressures are always a little on the high side to extend trend life but they aren't best for traction.VFRSQUID said:
Look on the tire itself. The manual won't cover specific tire brands. it might give you a general range.
30-46 psi should be fine.
I agree with Chris on this one. The pressures on the sidewalls are maximum pressures only. I run D207GP on the track, normally 31lb front, 30lb rear (depending on tempurature). Only thing this is relevent for is that at 75 degrees F, after one session, the pressure had risen 5 lbs in both front and rear.chris_y2k_r1 said:
The reason his tire pressure went up is because he heated up the tires and the air inside the tires, thus the expanding air creates more pressure inside.swjohnsey said:The reason your tire pressure went up is that atmospheric pressure went down. Normally tires will lose a little air slowly over time, especially thin race tires.
Factory pressures will get you in the ball park. Unlike cars bikes run lower pressure on the track than on the street. As an example Metzlar recommends 35 front 39 rear for their Rennsports for the street buy 31 front and 28 rear for the track.
Oh doh! season my bad! I can read...swjohnsey said:He said that at the end of the season his tire pressure had gone up 5 lbs not at the end of the session. Tires that are heated up eventually cool down and the pressure returns to normal. This does not occur with changes in atmospheric pressure.
Actually, I meant to say *session*, so Chris had it right. My bad. I'll stop drinking now.chris_y2k_r1 said:
Oh doh! season my bad! I can read...Damn, I'm impressed - you were able to understand my lack of comprehension of what I was reading without me having to explain it. Nice shot
With that said I agree only partially because I am assuming that the temperature at the end of the season was higher than at the beginning. I could be wrong in that assumption in which case you are 100% correct.
That's right, let's not forget the question at hand.swjohnsey said:Don't get you panties in a wad. The guy orginally asked what the tire pressure was for a '96 ZR-6R because he didn't have an owners manual.
Just depends on how much traction you want. Up in WA I'd think you'd want tire pressure a bit lower so the tire would warm up well. But it also depends on the roads too, if you're not riding hard in the canyons then there's little point in 32 psi I guess. If you ride in the rain a lot then higher pressure makes sense too as you'll hydroplane less easily.fuster said:32 psi in the rear would be too low for me. Especially in the rear, that would be way too low.
I think that about sums it up.apexismaximus said:So many factors, that's why they make it so easy to change I guess. Every ride can call for different pressures.
