1 - 11 of 11 Posts
This 50cc 2-stroke engine is now being sold in California. Though you still need a motorcycle licence to ride it.
Some of the features include a belt driven overhead camshaft and one intake valve.
What is the make and model?
Hi Ninja,
In the head there is only one valve for the intake, no exhaust valve.
There is a second crankshaft that operates a second piston. :eek:
Andy
The crankcase is a standard 2-stroke, but instead of pushing air/fuel mixture into the cylinder, only fresh air is pushed in.
The revolutionary new design is in the head. There is a tiny crankshaft operated by a belt that operates a small piston, it first sucks in a very rich air/fuel mixture into this small cylinder. It then gets compressed to over 65 PSI. Then a small spring valve (the intake valve) opens up as the main piston is nearing top dead center. Once the air/fuel mixture is ignited the spring valve closes.
Your prize is a brand new Vespa. The only restriction is that you have to ride it instead of your sportbike. :D
Andy
1 - 11 of 11 Posts
