1 - 14 of 14 Posts
That little light above the headlight on my RR burned out. Has anyone done anything different with that like tinting, different bulb, etc?
"Ray, when someone asks you if you are a god, you say YES!!!"
I know Big Kahuna put in an Amber bulb to match his front marker/signal lights... I havent done anything to it personally. How about make it flash in sync with "STEP AWAY FROM THE BIKE!" alarm system? :D
Kyle J.-
email:[email protected]
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Troublemaker400:
what's that thing for?
Luke
<HR></BLOCKQUOTE>
Its a 'Daylight visibility light' for use in countries where daytime running lights (headlight) are not required.
Its to help the zombie cages see you on the Autobahn. :)
Kyle J.-
I put in a blue tinted bulb. It matches the look of my super white headlight bulbs better.
I have seen an RR around here that the owner had painted the little light bulb cover to match the rest of the fairing. I guess he doesnt have to worry about it burning out now :).
http://gsxr750.sportbikeworld.com -Almost finished!
Formerly known as GSXR750
I've been thinking about the ion bulbs for my RR. I guess you like them? Where did you buy them, Lockhart?
Riverrunner- I didn't know that's what the light was for either. Thanks!
:D :p ;)
Cool Tigerblade, I can be useful :rolleyes:
I know in CA. if you have any blue or red forward facing lights you get a big ol' slap on the wrist and I think a fine. Check that out before you color the lens...
I got busted as a teen for coloring the license plate light lens blue. It was just a fix it ticket though.
Kyle J.-
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by tigerblade:
<HR></BLOCKQUOTE>
I like them. They really seem to get noticed. I got mine from http://www.sportbikes.net
I got the 90w/100w, so there is not much difference between hi/low beams. Actually, I can't use the hi beam as it blows the headlight fuse. If I order them again, I'll get a lower watt bulb.
P
Guest
Drool...
Pete
"Ultimately, most problems can be solved by applying a large brick to the correct skull. Difficulties arise when you don't have a brick or can't find the the right skull. The Devil is always in the details."
Discussion Starter #12
Could I borrow your '51 sometime? You know, just to see if I like the bulbs? :D
"My life's in shambles. I need pie."
Honda Moderator
The "red" stuff is a pigmented clearcoat that I formulated myself to stick to unprimered metal so that the sheen of the metal comes thru the clearcoat. Looks like a red mirror in person... I have also done some R1's in blue.
Anodising is less than a micron thick into the surface of the metal & once it's scratched you're screwed... This stuff allows scratches to be buffed out and or reapplied in the event of a really bad crash
www.rc51.org
[This message has been edited by Lord Duckhunter (edited July 13, 2000).]
1 - 14 of 14 Posts
