whats the easiest/safest way to raise the angle on my tail? if i were to build brackets that extended the lower arm on subframe would that be safe? or should i find an aluminum welder and go that route ,thanks guys
I have never seen a swing arm extended by bracket and I assume there's an excellent engineering reason for that. Either having yours fab'd or buying aftermarket in a welded format is where I'd go if that was my thing.
