I'm going to be putting my bike away soon and was wondering, would it help to put synthetic oil in for the winter. I'm going to change it right before I put it away and also first thing in the spring. Would it be OK just to have fresh cheap oil in it for the winter and then change it for good oil in the spring?
Use the cheap stuff, and thicker single weight. The synthetics are good for resisting wear and breakdown of the long carbon chains that give oil it's protective and lubrication qualities. Sitting over winter has none of the characteristics for which synths might be an advantage. A thick single weight will cling better than a multi-weight and thus stay on the metal you wish to protect instead of running off and sitting in the sump where it does no good. In the spring, pour a tablespoon of oil in each cylinder (through the spark plug holes), turn the engine over a few times without starting then come back in an hour and start your bike. Let it warm at idle for ten minutes, take a short ride to really warm the oil, then change the oil to your standard choice.
S
Guest
Use cheap OIL for storage!
The reason you change your oil prior to storage is because the deposits in the oil are very bad for your engine.
When I change my oil, I use Castrol GTX 10w-40 (personal preference) I buy a 5 litres from Wal Mart. Drain the oil leave in the filter. Add 2.5 liters of oil run for a minute of so. Then drain.
Remove oil filter, add new one. Then fill with remaining oil.
I do this because I have a Dual sport which frequently gets offroad. When I go off road I constantly dump my bike the engine will flood and this leaves unburnt gas in the oil. Not good for the engine :). The same can happen on short trips on your bike.
Now I'm not saying to flush your engine at every oil change, but I would consider it for storage purpose's.
S
Guest
Re: synthetics
thothscribe said:
Also - don't use synthetics then go back to regular oil. If you want to go synthetic, stay with it until the end. (Only recommended if you race)
Yes, a few years ago this was true. Todays synthetics like Mobil1 can be switch from synthetic back to dino oil with no problems.
