1 - 15 of 15 Posts
Help Me!
I still cannot get my bike to wheelie in second gear. How many rpm's should I be at to get it up? Someone with a 900 or better please help me:crying:
well I won't put in my .02 cents cause you can't handle it aparently. but why don't you tell us what your doing so we could advise you to do other wise. your bike should be able to do it, my old ass cb750 ss can.:p :twofinger
Autobahn,
I tell my customers to just drain the oil and then start the bike and run full throttle until it hits the rev limiter. This will totally destroy the engine even quicker than doing wheelies, and it’s safer too.
Seriously, doing wheelies, especially when you have to clutch it up, will destroy just about everything that turns in the motor and drive train. I think we covered this before, but here it goes again. When the engine is revved up to 5000 or 6000 RPM and then you dump the clutch, the connecting rods impact that massive crankshaft that has just dropped to about 1000 RPMs in a fraction of a second. The strain on the rods is similar to striking your workbench with a hammer. These stresses are way in excess of what the engineers had in mind. Also, standing the bike straight up in the air and then slamming it down on the pavement is also way off the scale it terms of the design limits of the frame and suspension.
Very few bikes will do a pure power wheelie in second gear. You obviously don't have sufficient horsepower, so you'll have to resort to some kind of engine destroying process to get the crankshaft momentum to do the work for you. Personally I recommend that you just ride the bike, and enjoy all the things that a normal two-wheeled vehicle can provide. By the time you find just the right combination of delayed clutch or quick snap of the throttle, you'll be ready to get a new bike, and let the next guy spend a couple grand to rebuild your destroyed motor.
DaveL,
I understand where you are coming from as a mechanic and I am not try to say in any way that wheelies are harmless to a motorcycle. However, I believe many of your opinions are mistaken.
First thing I think is incorrect is the statement you made about the loads handling capabilities of the chassis and suspension. Just about any new 600 or higher will lift the front wheel off the ground without trying. Especially with me on it at 135 lbs. The R1 will lift the front in 1st or 2nd without trying at all. The engineers design motorcycles with this in mind. As an engineer of any kind, you have included into the design anything a user can do to it. Otherwise you will have thousand of products being returned to you. Engineers study Murphy's law for this reason.
Back on topic, to answer your question Auto, your main problem is most likely timing. That and you want to pull the front up in as low RPMS as possible. Find a small bump in the road, hold the throttle at a little less than full open, take the RPMs up to about 5,500 and hold them there until you are at the peak of the bump. Right as the front tire hits the top of the bump, lean back and go to wide open throttle. As you lean back, try and pull the handlebars to your chest. It just takes practice. Make sure you do it in a safe place and be careful. Trust me that 900 will bring it right up, it just takes time.
chris I gotta say I'm with dave on this one, the engineers do design bikes as well as cars to be used to there limits, but not abused. thats why when you take the bike back after you cook an engine the first thing they do is scope the engine to see if there is bad scaring, if there is then your ass is paying for it. also if they did intend people to wheelie don't you think they would have solve the oil starvation problems.
damn did you say you weigh 135lbs, time to hit the gym buddy
They did solve the oil starvation problems specifically on the 996. It used to get an oil light when stood up, all they did was relocate the oil pickup. If a bike can bring the front end up under it's own power, the engineers design it to handle that. You never hear of an R1 being brought back for oil trouble due to wheelies. I never have and I've had my bike up for minutes at a time. I am very confident that Yamaha consider this when they build bikes. Otherwise, they'd have more calls, more new bikes being brought back to the shop (not to say it doesn't happen) and more bad press. Even if they don't cover the bike under warranty, each interaction costs money. I've had this conversation with a motorcycles design team that works with Honda. If you can do it to a bike, they have to think of it so it doesn't break. It cheaper in the long run
The only thing that power wheelies do IMHO, is kill the suspension quicker and break the mounting points of the plastic.
I have 15,000 miles on the R1. 6 months ago I checked the top end for clearance and did a compression check on it. Everything was well with in range. I does not leak or burn a drop of oil and pulls as hard as the day I bought it. I don't think that power wheelies with clean shifts are abuse.
chris_y2k_r1,
First let me say that I often overstate something just to make a point. I have had to rebuild many bikes this year alone, and all of it has been the result of abusive riding. I recently had a customer with a new GSX-R1000 with only 2,300 miles try to tell me that his bike was designed to do wheelies and stopies or anything else he is capable of doing. Even with about $2,500 in damage, he just doesn't get the message.
Today's motorcycles are becoming faster every year, but what you don't seam to understand is that they are also becoming lighter and easier to destroy. I am also being deluged with front fork damage, blown seals, damaged stem bearings. This damage is not caused by riding down the road. It is the direct result of doing wheelies, pure and simple. Many of us like to convince ourselves that the engineers have accounted for all this nonsense. It's a lot like the way we mistreat out bodies. We smoke like chimneys and because we didn't croak yesterday we convince ourselves that we can continue smoking forever. It just doesn't work that way.
Motorcycles will last a long time when they are treated properly and maintained. If you give your bike a regular diet of wheelies and power shifts, its longevity will be reduced in direct proportion to the degree of abuse. I've had five bikes this year getting complete engine rebuilds, none of which had more than 12,000 miles. I have 120,000 miles on my own bike, must be the gasoline.
well think as you wish, but no real mechanic that has any experience would agree. and why do you keep refering to yamaha, we are talking about a kawasaki here. anytime you abuse anything it wears down quicker, if you have a vette and burn up the rubber at every light it won't last long, the same goes for a bike, and everytime it hits the ground it does effect the engine, not just the mounts, its just like launching the sudden jolt kills the engine much quicker and usually more catestrophically(sp
)because of the extra inertial force being placed on the rotating assembly. thats why drag bikes, even though they are built for launching need rebuilts quite often. its just more stress then the bikes are designed for. and if the so called design team says other wise then they must really just be coffee boys. no offense.:twofinger
DaveL said:
chris_y2k_r1,
Your point well taken. I am quite sure I won't see 120,000 miles on my R1. I accept this but I do think that you can find a happy medium of fun and longevity.
Davel
You use that expensive racing gas don't you, I hear it'll cure front end wobles, blown fork seals, and bad helmet hair in just one tank full. Read it on the net!!:D
I'd say learning to do stunts does do damage as I went through 2 sets of fork seals and probably should replace the stem bairings after some of my carrier landings. However, now that my landings don't result in seismic activity I think the wear is minimal. The whole point of stunts is to get good enough that they look smooth and easy. Once you can do this the wear is probably well within design limits. Until then you are definitely going to have premature failure potential.
Plus, I weouldn't clutch up 2nd gear wheelies, they should be the bounce and power up type which would result in no unusual stress on the bike IMHO. (I can't do'em on my bike without a big rise in the road. I blame it on 5-speed tranny, weight, cheap gas!!)
chris_y2k_r1,
Now you’re talking. I think you're exactly right about finding the best combination of fun and longevity. If the bike is an R1 or something equally potent and short of wheelbase, wheelies can indeed be done with a minimum of permanent damage. I have 170 hp and keeping the wheel on the ground can be a challenge.
With Autobahn, however, I like to stress the importance of just riding the bike and keeping the rubber side down, for a while at least. I mentioned somewhere on this website or perhaps another, that I can remember never having an engine overhaul all year long or for several years in a row. With the wheelie mania in vogue today and even with the much better engineered machines, the major work is on the increase.
Happy Medium
Well Dave, actually this R1 is the first bike I've managed almost 20K on without any major motor or tranny issues. Prior to this bike I've owned a Ninja 250, Ninja ZX-6 and an R6. Both Kawis had rod bearings problems before 5,000K. The 250 threw a rod more than once. The R6 broke the dentent spring, which was a common problem with the 1999 model, but after that it was never right again and eventually ate up second gear. Mind you I did not shift in wheelies with that bike nor did I use the clutch. The R6 would power it up in 2nd without any extra-ciricular activities.
The R1 is the first bike to hold up as well as it has under the stress that I have exposed it to. However, by the time I purchased this bike I had learned how to lift the front with mininal stress on the drive train.
I agree with your advice for Autobahn.
if bike manufacturers would throw a couple of pounds back into bikes and make the magazine weenies write the articles after the weigh-in's, i don't think things would be as bad.
just my $.02.
i know i would gladly tell suzuki to add a few pounds to that gearbox and make it as smooth as a suzuki box should be.
This is how you do it in 2nd gear
You wan't to know how to wheeile in second gear this what you do. Get your R.P.M. up too about six grand and without touching the clutch pump the gas once let off and pump it again quickly and you should be wheelieing in second.That how i wheelie my CBR900RR in second gear and i have no problem with it going up. I like doing it this way,because you have a better feel and control of the power pumping the gas then clutching.also try putting on a bigger sprocket if you have a 43 tooth rear change it to 45 but becareful cause you will be able to flip it faster.Take your time at first AUTOBAHN go to a long empty road with no traffic and you get in no time. GOOD LUCK. P.S. let me know how you do.
All this drama over one simple question, such a waste. Magic words bro, "throttle pop" and "bounce". No harmful clutch techniqes should be needed. Oh yeah, wear your skid lid squid.
1 - 15 of 15 Posts
