1 - 12 of 12 Posts
Hey again...
Missed thursday night for good reason. Yeah it seems I wrecked my bike up pretty good. I already ordered the parts new cover generator, gasket, tailight. I lucked out getting out of the parts bracket for about 100 big ones.
In terms of plastics she's screwed. The fairings are just scratched except for the chunk I took out by the windscreen. A lot of the inner plastics by the dash are broken up so bad I'm not sure I have all the parts. OEM's are out b/c they don't make oem plastics so...
Does anyone have a plastic welder I can borrow? I know I can get away with a sodering iron but I want to get this as clean looking as possible.
As for paint can I just try and color match it or should I start over with a new paint job?
After all this getting high sided seems like small fries next to straightening the forks and throwing on all the new parts. Any advice for the job would be appreciated.
Steve I hope you can help with this one...
yeah man u ok? howd this happen? i know ur a newb, so you probably learned a good lesson whatever happened, right? cause i know i sure did my first year, i wiped bad. dont fret, plus its your first bike, who cares if its beat up you will have a new one in a year or two.
so fill us in, we like crash stories...well not like, but you know what im sayin.
try ebay for plastics, and any other parts you may need. i would then proceed to give it a whole new paint job, and if it were me i would take all the fairings off and use some type of simple spraypaint. reasons being #1 its quick, cheap and easy #2 its an old bike #3 you might drop it again and with spraypaint its an easy color match and easy to fix #4 who cares what your 93 ninja 600 E looks like its not gonna be winnin any shows right? as long as it rides good and looks decent, ur golden for a first bike.
just my :2cents: and if i were you i would carefully review in your head what happened and how you can prevent it next time you ride.
lol yeah. I took off hard around a corner and slid out and around. There was a ton of dust on the road from construction that I didn see until its too late. I couldn't ease of the gas fast enough and I got spun around an thrown off backward down a ditch. I messed up my ankle pretty bad. But my gear did even scratch just picked up some dirt clods.
I think I did a few flips on the way down. It must have been a pretty impressive flight, as a lot of people stopped to help making it even more embarassing. The bike laid down and rolled over itslef. I g2g do some drywalling lol. So I'm walking just isn't my first choice of activities. Thank god for pain killers.
More details if I've got time.
Sorry to hear you wrecked. If no one has a plastic welder, I wouldn't spend the $100 they want to buy one. A soldering iron does just as well. If the back side of the broken part isn't visible, tack it in place with the iron and lay some fibre glass over it. Thats what I did with my bike and it looked good. Just remember to lay bondo over the visible portions and push it into the small gaps that will be there. Sand it over until its flush and you won't be able to tell. If you just plastic weld it, I don't think it would hold to well, but fibreglass backing on it helps out alot. Good luck, hope your ankle heals up, and take it easy.
Sepias
I know Lou_Brakant has one, but I haven't got his #, and haven't seen him on this board in a while. He may be on DSR's (Stuntlife) board though as well. Try and get in touch with him or someone here may have more contact info for him
Yeah I know exactly what happened. The tuner behinde me was revin his engine and I was like psh... I'll show him. I hit the gas on what happened to be a dusty turn and whoa shit your gone. Lesson learned don't show off when ur ridding on a budget lol.
bmacd said:
it's ok that you didn't learn your lesson b/c you're going to do it again until you're hospitalized. Play it safe out there brother...too many riders are going down already this season.
-=bmacd=-
what ya mean i didn learn my lesson... I was riding beyond my ability trying to show off taking a turn too hard. how does that mean i didn learn my lesson:confused:
You'll do it again. I know exactly where you're coming from...I'm growing out of that phase still myself.
-=bmacd=-
Plastic welder is ok but if you understand how they mold ABS it is easy to fix. It starts out as lil pellets and is mixed and heated with Acetone until it is a thick liquid. It is then put into its mold (not all processes involve the acetone but bear with me) and heated. The acetone gasses off leaving the part. Buy some ABS from a hobby store or find some extra bodywork laying around. Clean the paint off of it and cut it into little strips. Get a glass jar and put all of the ABS you can into it. Fill jart about 1/3 with acetone and put lid on it. Let it set and the ABS will disolve into a thick glue like substance. Use a thin dowel or coat hanger to spread the mix on the crack and hold it fr afew....it will harden quickly. It melts itself into the surrounding area without heat.....and if the stuff in the jar hardens...just add more acetone.
1 - 12 of 12 Posts
