I'm looking at buying a 1996 CBR600. I like the look of a dual saddle seat better than a single sadle. Is it possible to put dual saddles on it?
Thanks
Keith
yup
forgot the pic ;)
ok i'm sorry, my post was not as i ment it to be. I would like a split saddle. Not a single saddle. If it's not possible to get a split saddle do tey sell seat cowls. Something to cover the rear portion of the seat? Also, for all yall CBR F3 owners. Is there a Gas gauge?
thanks
keith
S370HSSV 0773H
I'm sure if you poke around enough you can find some sort of cowl. Try PM-ing 98cbr600-Solo from the Redline group.
I'm pretty sure there is no gas gague, our 2000 F4 didn't have one either.
Good luck!
S370HSSV 0773H
Well, the way I always did it (even when I did have a fuel gague on my XX) was to fill up and zero the miles. Then go about 80-100 miles or so and fill up again, figuring up your mileage. Do this a number of times, and make sure you ride normally. This will give you an idea of your average mileage. Take this and multiply by your tank's capacity and there is your maximum range (our F4 was around 160-180). I would usually take 30-40 miles off of this as a safety factor though, and start looking to fill up around 130-140 miles.
:thumb:
kjg: Most m/cs have an on/off/reserve switch where the fuel comes out of the tank. Some of the later models have an idiot light telling when one is on reserve & time to fill up.
Like spicer I would fill up, set the trip meter to zero & ride to where the idiot light comes on, turn into the first station record the milage on the trip meter AND how much fuel one took in. Set the trip meter to zero again. After a while I would know when to pull in for fuel before the idiot light came on.
As I ride a Yamaha 600 & Honda 929 I have two stickies on the tacks reading 360 & 290 for the 600 & 929 respectifully, in Klicks since we use the metric system.
Still on either when I note my trip meter is reading 200 I will start looking for a fuel station IF I am on a hwy I am not familiar with, but one I know well & the stations then I do a quick calculation & realize just 20 or 30 Klicks ahead is one of the newer stations & so NEW storage pumps (which means cleaener petrol then old stations with rusty & leaking underground tanks) & yes I can make that easily.
