1 - 2 of 2 Posts
I was wondering how could I get the scuff marks off of my TI graves can, the strap that holds the can up scuffed it up. Thanks
Hey there, the problem you're going to run into is that the Ti is not polished and has a uniform brushed look I'm asuming or something similar. Anything you use that would actualy remove the scratches will have to cut the surface around the scratches to remove them. Same thing goes for paint, when I wet sand a scratch out I am actualy cuting the clear coat down inthat area to the level of the deepest part of the scratch. What you will end up with is a shiny section becase the surface texture is gone. You basicaly have to do the whole pipe or leave it.
Hope this helps
1 - 2 of 2 Posts
