1 - 2 of 2 Posts
Ok, here it is. I have an Akrapovic Bolt-On with stock air filter on my '03 954RR. I also have a PowerCommander PC IIIr that I wrestled into the bike's wiring system. Now...I go to find a map for the exhaust configuration and all I can find is the full-exhaust with stock air filter map.
Does anyone out there have a good map for my configuration or a recommendation of what I should use? I'm tempted to just go with Erion or Two-Bros bolt on maps, but want to get the most out of my system.
I wouldn't see any reason not to go with the Erion map. I had the same problem when I put my M4 Hi-mount on my F4i. I just found a pipe with a similar bend (the devil hi-mount) and used that. I've had it on the for over a year and seems to work fine. One of these days I'll get it to the dyno to get my own done, but until then I'm happy with the map I have in it. If nothing else, play with the maps you have and see if you can come up with something you like better.
1 - 2 of 2 Posts
