1 - 20 of 23 Posts
I just installed my new undertail on the R6. Now I need to place the license plate somewhere. If this photo goes through this particullar R6 is exactly like my R6, except for the logos on the rear sides. I would appreciate everybodys opinion on where to mount the plate.
My plate is mounted in front of the rear wheel @ the same place the rear fender is attached. I drilled two small holes in the fender, attached the plate, the reattached the fender to the cross piece on the swing arm. I've been pulled over twice & haven't had the police say anything about the plate. I've the same bike as in the picture.
Try mounting it to your exhaust pipe. I fabricated a bracket for my zx9-r and mounted an led light above the plate to make it legal.
Does your plate scrape the tire hugger at all? I am trying to figure a way to mount it like you did, I just need to come up with a way to light it up! I all ready have a blue neon strip but I do not want any blue neon under my bike. Do you know if there is a light strip of any kind for license plates for this purpose?
No, it's attached to the hugger. I'll try to attach a pic
R6steve said:
here's another pic that may be better.
Sorry if they don't come out to well, I'm in the middle of a 520 chain/sprocket conversion and there's not much room in the garage to take the pic.
I am going to go down to radio shack and see what kind of lighting they might have for lighting the plate in the location you put yours; then I am going to go place mine in the same place. If it turns out good I'll post pictures. It looks so F***ing awsome right now I don't want to drill any holes in the undertail anywhere! Especially, after all the time it took to prep it and paint it. Thanks for the photos!!
By the way, is your pipe a dark red color? I appears to have a dark red color in the photo. It is definatelly a nice bike!
You need a dremmel to do some cutting but it wasn't too hard. The instructions their website are actually pretty good, I was able to do it in about an hour or so. I'm no wiz at this kind of stuff so I found it challenging but was able to get it to fit up just right without too much trouble.
Thanks:thumb:
Discussion Starter #15 (Edited)
Re: Re: Please HELP!! Need advice on license plate location.
R6steve said:
How difficult was the install on the undertail? Time & expertise needed?
I'd have to say that the most time consuming part of the whole undertail installation process was taking the time to properly spray the undertail. Also took a while trying to find the right color white. And sodering the wires (about 30 minutes). It is actually pretty easy.
Discussion Starter #19
What do ya'll think of this location?
What do yall think of this license plate location? Kind of hard to see because I took this picture late last night with a my new cell phone (camera built in).
1 - 20 of 23 Posts
