1 - 11 of 11 Posts
Just wanted to give a tip for anyone planning to paint there windscreen. DO NOT SAND IT FIRST. I painted mine black this weekend and it turned out really good.
Painted mine about 2 yrs. back and it still looks great. Easiest way to do it is....clean it with rubbing alcohol then paint. 3 coats should get it just fine.....any spray paint will basically do the job...if you want to spend the extra money get the new plastic spray paint.
Sundowners said:
I want a pic of your windscreen.. not your ass.
You painted it on the inside, right????
yeh paint the inside. if you want, you can get some compound(like 2000 grit) and rub it in. it will not only clean it up, but also very very lightly sand/scuff it. i did that with mine and it came out good.
Discussion Starter #11
Dont fret. I painted the inside. Also whacked my stock mudflap and turn signals and went with an intergrator. Dont have any pics at work but will try to post some tonight.
1 - 11 of 11 Posts
