I want to replace the rear suspension on my 87 600R but have been unable to find anything on the net for aftermarket.
I wanted to get a new 6R, but law school in the fall has forced me to breathe a few more years of life into my baby.
Anybody know of any aftermarket rear shocks???
Tried the classic board already...no life there.
Your best bet might be to take measurements of the shock height, width of mounts, and find a 600 - class (or EX500) aftermarket shock that measures the same.
Is your shock shot? Or are you looking for a performance upgrade?
I'm pretty sure Öhlins makes a shock for your bike and Fox might also. Don't forget to try progressive suspension. :)
6T9,
I have been riding an 89 Ninja 600R for the last 4 years and like it so much, I deceided to keep it instead of buying a new bike this year. (I have been contemplating a new Ducati)
I do not mean to offend, but you do realize that there are two adjustments for the stock rear shock don't you?
The first is the air pressure (preload). There is an air valve under the right side cover. I am 6 feet tall and weigh 195 and run at zero. To get it to zero put the bike on the center stand and depress the valve to allow built up, or negative pressure (occurs when sitting on side stand for a long period of time) to release. If you decide to add air, DO NOT use compressed air from a tank! You will blow the seals! Use a GOOD manual bycycle pump with a gauge inline or take it to your local Kawasaki dealer and pay the $40 or so to get it set up right. The manual says max is 70 psi. I would not exceed 30 or 40 psi if It were my bike. I think you will probably use 0-20psi for your situation.
The second adjustment is Damping force. This is done by changing the position of the adjusting stick also under the right side cover. There is a small black knob on the end of the adjuster. Fully pushed in (position 1) is the softest setting. All the way out (position 4) is the Harshest. I run at 3.
I run Avon Super Venoms front and rear and have no complaints.
Best of luck.
idk im new to this zx6 question
i have a 91 zx6 ninja just put a new motor in it with less than 6thou miles! i started it and it pings around 2 grand and down! wen i let off the gas! IM NOT SURE IF IT CARBS OR SOMETHING ELSE woundering what kinda issues other might have hadd simler to this and what it was
