1 - 13 of 13 Posts
Got done yesterday (will be able to wallpaper the spare room shortly) for the Corsa's (front & rear) not having cuts running to the tyres outside edge????
Admittedly the rear has some good tear marks a couple of inches in from last time out, but Mr Piggy's problem was that there is an inch or so without any cuts. He said the actually tread depth was fine as it has to be 1.5mm which it is (and some - maybe 300-400 km's on the rear in all). He then took a couple of pics!!
Even the Pirelli spec sheet says the Supercorsa is 'optimised for use on public roads'....????
Once I'd had a go at getting off he started on about rearsets not having rubber inserts (what a dick) and the braided lines, so I just let it go.
Now suppose to replace the tyres (both), get a roadworthy and then visit the local roads neanderthals for the big tick.. or I could fight it and see what happens??
Useful advice appreciated.... :D :twofinger
You must be taking the piss !! .. ???
However, I still can not help but bite ....
1. In NZ the rule is 1.5 mm tread over 3/4 of the tyres width .. hence the legalisty of the Corsa tread pattern. It would appear your man believes the tread must bo on the complete width.
2. Farking rubber inserts ?? ..... ask him to name a sportbike the DOES have these as standard ..... if he mentions the 'blade tell him that is NOT a sportbike.
3. Umm ... what was his problem with braided lines ?? ..... how can this be contrary to roadworthyness ....
And finally .... are you telling us the whole picture .... or was it the 2 k wheelie you pulled past him on the motorway at 180 kph that pissed him off ??
Davo .. fight the carnt. Kill his cat. Send a message.
Braided lines ???
Whats the story with his objection on the brake lines, not allowed to improve saftey over there ?
The Supercorsa's are road legal in most countrys but dont know if its worth fighting. In the words of the Clash "I faught the law and the law won, I faught the law and the law won !"
What is the penalty so far ? Replace them and its a done deal or is there a fine ?
Yeah you would think something that improves braking would be encouraged.... :confused:
Just shits me as they as suppose to be DOT approved so where's the problem? Local law states "Every tyre must have a clearly visible tread pattern on all parts of the tyre that normally come in contact with the road and have a minimum tread depth of not less than 1.5 mm" which it has.
Damage so far is limited to a $160 fine - no demerit points and they must be replaced within 28 days, but what am I going to replace them with?? If I put on a new set of corsa's they prob. won't pass them either???
No big long wheelies this time, was actually stopped at a set of lights just into my 5km odd ride home when the tosser pulled up next to me. Maybe I'll talk with Slasher and see if he has a local contact for me?? :cool:
shite Dave
I know that in Germany for instance, you have to have any and every mod approved for insurance purposes. Something to do with variations from the original certified vehicle.
Take it up with the Pireli importer see what he says.
I'd be interested to know as well
Cheers
Discussion Starter #6 (Edited)
Just spoke with the main man at Pirelli OZ on all this, and he says that it's all BS and the tyre is completely roadworthy. He's sending me a copy of the approp. legislation and a letter stating all that and more.
Suppose that means I'll have to take it a little further and see what happens, hardly worth the pain though really??
Killing his cat may be quicker and would def. require less effort?? :cool:
You know the worst thing, the bastid was a New Zealander.... and I'm not joking Ledge he actually was a sheep shagger like you :twofinger
Working on the disapearing cat act for one night later in the week.... :D
Latest update is.....
Looks like I'm off the hook for fine on the tyres thanks to a lot of help from the local Pirelli guys... but NOW I'm told I can't get a roadworthy certificate with removing the rearsets (pegs must flip up rather than be solid) and I also have to remove my Ti Yoshi pipe!!!! Even though everyone runs a pipe without any problems....
Am now seriously thinking I'll go out and get a bike trailer and leave the thing unregistered for track use only. What do you guys think??? :crying:
Location?
Dave,
Which state are you in by the way?
Switch Switch
Switch the exhaust and the pegs to originals for the inspection and then switch them back to your aftermarket units after the inspection.
Discussion Starter #13
I'm in inner Melbourne, Victoria..... about 1:20mins from Phillip Island :cool:
Will def. not leave the pegs and stocker pipe on there, just have to keep one eye in the mirror for a little while.... :rolleyes:
1 - 13 of 13 Posts
