OK....My rings and head are back on...LOTS of compression...I have power FROM the magneto, as MY headlight turns on and the horn works when The motor is kicked over...Problem is NO SPARK....I have continuity across the condensor to the points...I wondering if I installed the points incorrectly???It looks like they only go on one way.( slotted/keyed)..I did have weak/intermittant spark, before i changed out condensor/points...So I guess I'm up for suggestions ....I don't believe that the coil is bad..Any Help is appreciated...P.S this is for a 50cc moped which I am restoring for my wife...Thanks!!!!!Jimmy G.
