1 - 10 of 10 Posts
Hey everyone. I would like to get a smaller front sprocket for my bike ('98 ZX6E) - (seeing as I don't get to do 140 very often)
I would like to improve the low-end acceleration. Is there one brand better than another? Can someone recommend one? Thanks in advance!
most sprockets are made by respectable companies..afm, renthal, vortex, you name it. you might have to get a whole new 520 setup, unless you already have it. I think it is a very sensible move, since top speed isnt really a factor on the street.
Desmo,
Go up three teeth on the back sprocket instead of down one in the front (They will eaqual out the same).
Why?
#1 A smaller sprocket up front is harder on your chain as it now has to bend tighter to get around the smaller sprocket.
#2 On some bikes a smaller front sprocket will cause the chain to rub on the top of the swingarm.
One thing though, if you decide to get a bigger back sprocket you will need to make sure your chain currently has enough slack for the longer length.
I know this might not be in the budget for everyone. But When my chain bites the dust I also change both sprockets at the same time.
I agree. When I change the chain I will also change both front and rear sprokets. Money spent wisely know saves on money saved unwisely. It is a small price to amke sure your bike is in tip to shape
nothing worse than buying a new chain and letting an old sprocket tear it up.
Discussion Starter · #7 ·
Thanks for all your help guys. I wanted to get a few opinions now so I could shop around this winter. I've got time seeing as there is 3" of snow on the ground.
Bummer. We haven't gotten any snow yet (though they predict "snow showers" over the next few days). Still, I rode to work this morning, even if the temperature was around 37 degrees! :)
Discussion Starter · #9 ·
37 degrees? wow, you're a better man than I am. My commute is 45min one way, so once the temp dips below 45, I take the car.
If my commute was that long, I would take the car as well. As a matter of fact, last year I had to commute into Manhattan, about 1 hour or so away, so I took the car in winter, but the bike a few times with the warm weather. Manhattan isn't friendly to bikes in the best of conditions; bad weather aggravates things by a factor of 10, in my opinion.
Now I have only a few miles to travel in the morning, though I often have to go 10 or so miles in the evening to another job I have. Still, as long as it isn't snowing (or threatening to snow like today) and there is no ice out, the bike can be used. Not every day, but once in a while to keep my spirits up! :)
1 - 10 of 10 Posts
