1 - 18 of 18 Posts
I have a nail in my rear tire, but unsure for how long it's been there. the head is shoved down and crooked, so I can't tell how big it really is. I ride at least every other day, and I check my air pressure twice a month (I should do it more). the rear was 10psi under my normal, but I have had the tires 5-10 psi under before.
There's probably 1000 miles left on the rear. I know I shouldn't ride on it, even though I rode it home 50 miles at 75mph after I saw it. I guess I'll practice some rolling burnouts and donuts to chew it up, because it's not worth the cost of plugging/mounting/balancing with 1000 miles to go.
I would probably ride on it if I only did city driving, but Im constantly on the freeway pushing 75mph. this sucks.
What's worse is the construction boom in Phoenix will never end; there always shady construction trucks on the road with crap flying out, so my next new tire is just as likely to get a nail. Ive lived here for 2.5 years and this is my third vehicle to get a nail in the tire.
Im thinking about stealing a used tire from the pile of tires that sit behind bike shops. Good idea or what?
I am not telling you what to do...but if you do a burnout with a nail in your tire, you are asking for it. Lets say you get lucky and the nail is shot out of the tire at 100+mph and it just ruins your bike. Lets hope you dont kill an innocent bystander.
As far as "stealing" used tires...if you go in and shoot the shit with one of the service or parts guys for a few minutes and just slip in a "hey, how about those tires", you may actually get somewhere.
In any event, that sucks and I hope the shop gives you a free one. :)
Even if you get that used tire, wouldn't it cost the same to mount and balance the tire as a new one? If you really want to skip out on getting a new tire for now, then pull the nail out of the tire and use tire slime. It works, but I'm not saying you should do it, still risky.
Hen- I don't think I said I'd be going 100mph. When I say rolling, I mean 2 mph, while the tire is spinning. I made it home going 75 and Im not going to push my luck anymore.
Z- You make a good point; why spend $30 for mount and balance on another piece of junk.
Hi Mr. TrevorClever-
Here is what I would do in your current situation:
  • remove nail with pliers
  • roughen hole with file
  • insert plug smeared with rubber cement
  • allow plug several hours to cure
  • ride repaired tire to maximum speed of 65 m.p.h.
As long as you're not riding like Nicky Hayden, the plugged tire will be perfectly serviceable for the next few weeks until replacement.
~ Blue Jays ~
Mr.TrevorClever said:
...When I say rolling, I mean 2 mph, while the tire is spinning...
Okay, so you're doing 2mph "ground speed', but what speed is your tyre spinning at???
If you're dong a burnout with a nail in your tyre, you don't know when / if that sucker's going to come loose and shoot out.
Thank you Cookeetree. I could not even respond to Mr.TrevorClever last post. He thinks that when he is doing a rolling burnout at 2 mph his back tire is only going 2 mph.
Not to mention, I said...
The nail is shot out of the tire at 100+ mph...THE NAIL, THE NAIL
not your ground speed.
Super Moderator
I've said it before, and I'll mention it again. Motorcycle tires undergo some pretty dynamic forces. The front has to bear it's share of the weight, and deal with crazy cornering forces, as well as the majority of the braking force. The rear has to bear it's share, which can be even larger due to passenger etc, the same crazy cornering forces, it's share of the braking (whether engine or brake) and 100% of acceleration forces. I wouldn't trust an external type plug unless it was an emergency means to get me to a more permanent repair. If the tire had enough life in the tread and compound to continue to use, I would use an internal plug patch and go very easy on it. If it didn't seem worth the cost of removal and replacement due to tread life/compound life, I would get a new tire at that time.
It's just not worth it to me, to take that type of chance with my machine, my self, or others around me.
At the same time: I've never known anyone personally have one pull through (although we all hear stories about the friend who has a cousin who met a guy that got soda from someone who read about someone who heard someone else say that they saw someone lose a plug).
Being on a motorcycle is about acceptable risk. If you believe that the plug is accpetable, do it. If not, don't. I choose to not take the extra risks.
Hi All-
The original poster mentioned that he will be replacing his tires soon, so a correctly-installed plug seems like a reasonable choice until the new ones are spooned onto his rims.
~ Blue Jays ~
I've been riding for more than 20 years, and I've put many thousands of miles on tires repaired as Bluejay described. The last time it happened, I put on all of my gear, went out on a country road and ran at speeds around 140 for a couple of miles. I risked my *ss so you won't have to....
Bottom line - the plugs work, if used at sensible speeds and if the tire isn't worn to or past the wear bars. I will make these 2 exceptions - NEVER on the front tire, and I add a little Krazy glue after I've pushed the plug in about halfway.
Discussion Starter #13
Im too busy to deal with the nail, so my bike will sit until I get some new tires. Tell me where to get the plug/cement kit. I might do it from the inside once I get the old tire off and the new tires on.
How on earth, or why would anyone do a burnout with the wheel spinning at 100 mph...ground speed...whatever.
My bike has enough torque to break the rear at 4k RPM in 1st gear, which is about 40 mph. There is not a bike built that can hit 100mph in first gear, so to make this possible I would have shift up to 3rd while doing the burn out.
I understand peoples' concern about doing a burnout on a bad tire, but don't try and use exagerated scare tactics on me.
Not relevant, but new literbikes putting out 150-160 rwhp can hit 100 mph in 1st gear. It just depends on the bike and how tall the gearing is.
Man...This is my last post on this thread because Mr.TrevorClever is making my head hurt...
Your bike will do almost 100 mph in first. Some of the new liter bikes will do over 100 mph in first. The ZX-12 will do 107 or something like that in first gear.
Also, I would bet you a million dollars to a roll of paper towels that you do burnouts way above 4000 rpm's. You may have the low end torque on that beast to cut it lose at that, but you run it far higher during.
The first thing I said was totaly correct and you have been trying to dig your way out of your dumb ass idea ever seince.
Thats all.
:laughing: :laughing: Nice.
You're too busy to deal with the nail?
The bulletpointed directions I provided on the first page of this thread would have you up and running within minutes. The cement would be fully cured within a few hours and you would be really good to go.
~ Blue Jays ~
Dude, buy a set of tires at Victory BMW in Chandler, or I think any other Ride Now store. They have tire pcmp's that are 500 bucks, and good for three years. They cover any tire damge from nails etc. As long as your tire gets a nail in it before it wears out you have tires for three years for 500 and the cost of one set of tires. --Word up to the mothership.
1 - 18 of 18 Posts
