Believe it or not, we were looking at making a pair of these when I decided to do a search and see if anyone already had a kit out there....sure enough, look what I found.
Specifications
Length Powered Skate: 19.25 in.
Height: 14.25 in.
Width: 7 in.
Weight Powered Skate: 12 lbs.
Engine two stroke: 22.5 cc
Horse Power: [email protected],000 rpm
Ignition: Electronic
Carburetion: Diaphragm w/purge pump
Fuel Premixed: Unleaded
Fuel Capacity: 15 oz.
Running Duration: 1-1 hrs.
Transmission: Single Speed Centrifugal Clutch
Maximum Speed (approx.): 25 mph
Wheel Type: 77.5 m.m. in-line stock
Drive Wheel: MOTOSK8 Drive Wheel
Braking: Rear drag
Riding Tips: MOTOSK8 believes safety is a must when skating. Helmet, gloves, elbow pads, wrist pads, and knee pads are strongly recommended when using MOTOSK8. Thoroughly inspect your skates for loose or damaged parts before each use. Do not use until adjustment or repairs are made. Always obey local vehicle regulations.
Adult supervision is always necessary.
Allow up to 4 weeks for delivery
Made in the USA!
Specifications
Height: 14.25 in.
Width: 7 in.
Braking: Rear drag
Made in the USA!
