1 - 10 of 10 Posts
Question 1: Do Mille's have that wierd cut-off gyro thing that some GSXR's have that shuts the bike off if it leans over too far?
Question 2: Are Mille's known for having persnickety electrics that burn out randomly?
Here's what happened: At the end of the 4th session of his trackday on Saturday, my husband was coming around a corner on our 2000 Mille when he said it went "kunk kunk kunk" and then the motor shut off. Nothing locked up, he didn't crash. But now the bike won't turn over. When pushing the starter, it makes a loud kachunk, but doesn't make any attempt at firing. There's no grinding sound or anything. There was a puff of oil on the lefthand side of the bike, half on the frame, half on the tank, and more oil on the inside of the tank once opened. All hoses are attached as they should be, it's not leaking anywhere, oil levels are where they're supposed to be.
Any thoughts?
I have heard of some minor electrical things, like the clock and guages resetting if they don't get enough current, but nothing major. Have you found out yet what happened in your case?
Nope. :dunno: Hopefully this weekend. It's not looking good. :crying:
Klunck Klunck sounds like money money not electric?? Sorry
On the brighter side you can get that stroked crank and bore it a bit with the rebuild:(
All the positive thinking in the world didn't prevent it from being seized. :crying: :crying: :crying:
Really!? Bummer! Those rotax engines are usually bulletproof! I have never heard of one seizing. Are you the original owner? If not, I always wonder what kind of abuse bikes are subjected to (maintainance wise.) Maybe that's why I am so reluctant to by used. I know, from a resale standpoint, buying used makes a lot of sense, but not whin something like this happens. Sorry.
We bought the bike used, and we know it's history, unfortunately.
It was purchased new as a first bike by someone with zero experience. It had 7K miles in 2.5 years, mis-matched tires complete with 1.5 inch squid stripes. The previous owner would ride it to the local hangouts to pick up chicks. He dumped thousands of dollars into top-of-the-line upgrades and never rode it. He finally sold it when he realized he was in way over his head.
Cycle Moto swore they did a valve adjustment on it before we bought it, and promised us that they had done all the regular maintenance and installations on it. We had our own mechanic go over it with a fine-toothed comb before the trackday. It had new brake pads and rotors, new sparkplugs, all fluids replaced... It was running perfectly. :crying: :crying: :crying:
i've never heard of any oiling problems or anything. that's odd. it may be the first seized aprilia rsv motor in the states. not that that helps.
You dropped a valve
Sorry,
I just came across this thread.
Novice and Intermediate riders tend to over rev Milles on downshifts. I've been directly behind TWO people that did this and they both crashed when the valves stick in the cylinder and seized the engines.
After an intake valve breaks the broken pieces go back up into the air box and usually get sucked into the "good" cylinder and ruin it too.
This is caused by one thing only.... over reving the engine on downshifts. A slipper clutch will only protect your valve train for so long. Brakes are made to slow bikes down, not compression braking via slipper clutches. This is teh only draw back of a slipper clutch. It lets you get away with stuff that with out it would have put you on your head on any other bike.
Sorry to be so blunt but I've been around Mille's longer than most and this is almost for certain what happened. You're looking at big $$$ to fix this thing. Couple of grand maybe more. For sure Pistons, Valves, Heads, maybe both cylinders. Ouch...
Good news is that Blackmans has a kick ass stage 3 kit that is about the same $$$ as OEM stuff and now you can have your 130+ HP Mille...
1 - 10 of 10 Posts
