for all you gixxer riders. can you give me the odds and ends of this bike. any information about the bike would be great. any! thanx
Here are all of the factory specifications;):
MSRP: $7,799
Engine: 600cc, four-stroke, 4-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
Bore/Stroke: 65.5 x 44.5 mm
Compression Ratio: 12.0:1
Carburetor: Mikuni BDSR36, with main air control
Lubrication: Wet sump
Ignition: Digital/Transistorized
Starter: Electric
Transmission: 6-speed, constant mesh
Final Drive: RK52GSMOZ chain
Overall Length: 2065mm (81.3 in.)
Overall Width: 720mm (28.3 in.)
Overall Height: 1165mm (45.9 in.)
Seat Height: 830mm (32.7 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1385mm (54.7 in.)
Dry Weight: 174kg (383 lbs.)
175kg (385 lbs.)CA model
Suspension:
FRONT: Telescopic, coil-spring, fully adjustable preload, cartridge type, compression & rebound damping
REAR: Link-type, gas/oil-damped, fully adjustable preload, compression and rebound damping
Brakes:
FRONT: Dual hydraulic disc
REAR: Single hydraulic disc
Tires:
FRONT: 120/70 ZR17
REAR: 180/55 ZR17
Fuel Tank Capacity: 18.0 liter (4.8 gal.)
Color: Blue/White, Red/Black
Factory Features:
-Compact and lightweight 4-stroke, 4-cylinder, liquid-cooled engine with DOHC, 16 valve/Twin Swirl Combustion Chamber (TSCC), and short downdraft intake ports for high combustion chamber efficiency.
-3-piece crankcase design minimizes engine length and simplifies transmission service.
-Lightweight shim-under-bucket valve train has narrow 29° included valve angle and lightweight aluminum spring retainers.
-Suzuki ram-air induction system pressurizes the airbox for optimum fuel/air mixture and high engine performance.
-SCEM (Suzuki Composite Electro-chemical Material) plated cylinders minimize cylinder-block width and improve heat dissipation.
-High efficiency liquid-cooling system for optimum engine operating temperature-includes compact liquid-cooled oil cooler.
-Lightweight magnesium valve cover, breather cover, signal generator & starter clutch covers, and sprocket cover.
-Convenient hinged fuel tank swings up to simplify maintenance.
-Digital, direct-ignition system is simple, lightweight and produces hotter spark.
-Lightweight electric speedo and tachometer with LCD displays, twin operation tripmeter and odometer with memory protection.
-Twin-spar aluminum frame construction combines is extremely strong and lightweight.
-Short wheelbase and 24° steering angle provide responsive steering performance.
-Lightweight aluminum swingarm construction combines extruded arms with a cast pivot section for high torsional rigidity without external bracing.
-Proven link-type rear suspension with fully adjustable piggy-back style shock absorber.
-Powerful staggered size, 4-piston front brake calipers.
-Dunlop Sport Max Radial tires mounted on new lightweight cast aluminum wheels.
-Wind tunnel tested fairing and tail section.
Blue Gixxer - I have had mine for since new and love it. If you have any specific questions about the bike let me now.
gsxr750y2k - Good Answer!
