Does Kawasaki still have to honor my warranty if I lowsided? Rash on the stator cover, upper, lower fairing, nose cowel and tail section. Also, busted shift lever, peg and broken mirror. The damage was only cosmetic. This was about 4000 miles ago. Now, the bike is only firing on 3 cylinders past 9000 rpm. The verdict is a coil that not firing right. The bike is only putting out 68.7 horsepower. The tach climbs slowly and chases redline forever.
Only one way to find out... I think it would depend on the dealer
I"m not sure but unless they "the dealer or Kawi" can prove that becuase of your low side you are having this problem. If they do prove that becuase of your low side you are having this problem then no they don't need to hornor there warntee. But if they can't prove that then yes they have to cover it. Unless there is a clause in the warntee about accidents.
if there is signs of damage u can pretty much forget about it, most dealers are assholes.
