My friend bought a 2003 R1 for his other friend (big mistake and told him not to do it)..... anyways..... a month later the bike was stolen...... but found and recovered a week later......
my friend took the bike back and it now sits in his garage.
Here are the problems though.....
the ignition was broke to hotwire it..... any ideas on how much this item is and anywhere on the net that shows how to replace it??
second... the bike only has 200 miles on it and whoever stole it roasted the rear tire which means it was really hammered on and not broken in correctly!!!! How screwed is the motor??
I mean the company gives a brake in recommendation to follow to cover them and if you develope a problem and the company can link it to not following brake-in then they dont have to warrenty it........ so what i am wondering is .... do you think the motor was damaged that much by not following brake in?
We were going to change the oil ASAP and also send the old oil out to be analyzed. Also going to do a compression test on it.
Anything else we should check out??
thanks for your help!
The bike should be fine. It is often reccomended that the break in proceedure should not be followed by the book anyway. I have often heard that babying the bike will cause problems in the future. :hurl: Not sure how true this is. My bike is fine.
It should be fine.
As for the ignition. You may just want to pick up a manual and check your wiring diagrams. The Yamaha manual has the lowest cost of any. It used to anyway.
Sorry I could not provide a URL for you. Anyone else have advice or some more input on the break in thang. :)
i replaced a 00' r6 ignition, it isnt hard, the toughest part of it all is getting it off the bars. other then that just follow the ignition wires and it should just disconnect (male and female connections)then once you find where it ends take off fairings and whatever else is in the way, plug in and reverse process. I know it might sound difficult but it really isnt, just do it you cant make it anyworse, and as for getting new ignition, i went to a salvage yard and bought it there, it is half off msrp with everything you need ignition, gas cap, new lock for rear seat. hope this post helps. later.
Bike will be fine. I rode mine hard as hell as soon as it had 50 miles on it. It's a beast now! That book crap makes you end up with a slow bike. Tell him to sell it and get a 04.
