This is probably just me, but I thought I'd ask anyway...I'm riding along (just started about a month ago), and I'm feeling pretty confident...due to my newbieness I've tried to stay at speeds below 80km/hr and have stayed mostly on residential streets. I arrive on a clean, empty back road away from the residential area and decide to twist the throttle a little more, hit highway speed, just to get used to the feeling. now because I' m a newbie I still suck at keeping track of what gear I'm in. I shift up, twist the throttle a little bit, and the engine revs loudly, but I go nowhere (same thing that happens when you accidently shift into neutral). Is it possible to...i don't know, overshift on a bike???? it sounds stupid, I know. When I gear down I usually just tap until the shifter doesn't go down anymore, then I know for sure I'm in first...I figured it would be the same for shifting up, but I could be wrong...??? I don't figure it's possible to shift into neutral between 5th and 6th gear, so I'm thinking it's just my newbieness kicking in. This ever happened to anyone?
felix, Sounds like you accidently hit one of the inbetween neutrals. Yes it can happen to all of us.
Be a bit slower in your shifting up to a higher gear & more precise, like once you are at home in riding you can feel it click into the next gear.
Do a quick check to by rolling the bike forward & feeling it is going into gears above first & neutral.
Also you might find that the shift lever is a bit to high & in that way you are not obtaining a sound or precise shift up into that next gear higher.
If you to feel the gear change lever is a bit to high I think on your 440 Kwacker there is a possibly 10mm bolt & nut holding the lever on the spline of the gear change lever shaft. Remove the nut at the end, then the bolt & slide the lever off the spline. Then slide the lever back on only positioned more to your liking.
I have to adjust, especially the gearchange lever, along with rear brake pedal for cold weather & hot weather riding as a difference in thickness of the boots. Fact is you should be able to adjust the position of your clutch & front brake levers as well to suit your riding style, height, etc. Okay so it is limited, but all can be adjusted to some point.
I know smitty has a lot of experience, but I don't understand why you would say shift slower. Shifting to the next gear up needs to be a clean, swift, and precise movement especially when at Speed. This includes the coordination between you left hand and left foot.
Also shifting when the bike is off on a lot of bikes doesn’t help much. I have a harder time finding N on a bike that I’m unfamiliar with if the bike is off.
Just my :2cents:
He is not scooting along at a fast pace & I guess I should have said "slower & more precicely" meaning do not try to shift at a fast speed, especially when there might be a problem in getting into the gears as he seems to run into in-between neutrals. So he wants to know it has clicked into the next higher gear rather then assuming it has only to have the engine scream into higher revs.
Not a big deal and like Smitty said it's probably from your shifting technique. Some bikes require a slower firm pressure, especially when older like your 440.
Only thing I have to add is to ALWAYS shift up when you get into a false neutral.
Also, if it happens a lot no matter how you shift it may be the tranny in need of a rebuild but 99% of the time it's a rushed shift.
