I talked to a guy over there this week and he mentioned a few things to me...
- No need to buy rearsets, he's had countless stock busa's out there without any problems with the stock pegs. I have TLR pegs on mine...even better.
- No need to safety wire the bike.
- No need to change the coolant out to water. They've been doing this for years and years and they've only had 1 incedent where there was a coolant spill on the track.
Thought that would help us when we go in May. :2cents:
Nope. Not in novice anyway.
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Bike Preparation (Also know as "101 uses for duct tape")
[/FONT] [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]1) All bikes MUST pass technical inspection prior to admittance to the track. If your bike DOES NOT pass tech inspection, you will NOT receive a refund.
2) Tires and brakes must be in good condition. Tires should be at least 75% of new condition. Any tires that are bluing from excessive wear will be disallowed. Slicks are allowed in 85% plus condition. We will have on site tire service at each track day, so if your tires don't pass, you will have the opportunity to put on replacement tires to pass tech.
3) All glass, headlight, turn signals, and plastic lenses must be taped over or removed. Side mirrors must be removed for the advanced group and at least taped over for all other groups.
4) We recommend, but do not require removal of center stands. No bikes with center stands will be allowed in the Advanced/Racer Group due to the ground clearance issue.
5) All machines must have an operational handlebar mounted kill switch/button and self-closing throttle in good working condition.
6) Advanced and Intermediate group riders MUST use water or water wetter or a non-ethyl glycol based anti-freeze/coolant. Approved Poly Glycol brands are:
[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular] Evans, 7th Gear, Liquid Performance, and Engine Ice[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]. NO AUTOMOTIVE ETHYL GLYCOL BASED COOLANTS ARE ALLOWED. [/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]7) All valve stems must have caps.
8) Wheel balance weights must be well-secured.
9) License plates must have bolts taped or be removed.
10)
[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Added for 2008 season:[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Advanced riders are required to safety wire drain plugs, oil filter and oil caps.[/FONT]
