Well a guy has a 1993 Katana 750 with 33k miles on it
he told me he could take 2k for it. It looks pretty good and doesn't look to be dropped hard (from the pics I saw) just minor scratches and a small dent in the tank.. probably dropped when not at speed...
He told me he would get any specific pics I ask for.. what else should I ask/look for in this bike? He says it runs good and is ready to go with newer tires. Says it doesn't need anything mechanically that he knows of. Also if anyone wants I'll post the pics up I have and if there are any specific pics I should get let me know. It would be a couple hours drive to go look at it in person so it wouldn't be worth my time unless I was actually sure it was a good bike to get. (excluding any forseen issues)
The only way to be sure is to have a trusted bike mechanic look at it. They can find things that you can't.
That said, what kind of riding experience do you have? That bike is fine to start on provided you know the basics (i.e. you've ridden other bikes or taken the MSF).
Well I have only had experience with a classic 175 yamaha enduro 2 stroke dirtbike. At the time I was shorter and actually had a hard time putting both feet on the ground lol. I used to ride it hard and abuse it and I can work a clutch on just about anything you put me on.. well except I'm usually over cautious and stall it rather than popping the clutch at higher RPM. (when I'm first learning that particular machine)
I'm somewhat worried about being able to balance it since I have researched tht they are a little heavy. I'm a big guy at 5'11" 250 pounds.
When I do for sure go get a bike I'm going to see if my older cousin will go with me to test ride it for me to make sure everything is shifting and acting fine. Do you know anything else I should be asking him that could turn my interest away or for you guys to help turn my interest away. It's good to find things like that before going through the hassle of waisting effort to check it out in person (it will actually be a few hour drive from me i think)
First, ask him to start the engine when its cold. Most of the carburated gremlins hide once the engine warms up. With the engine cold to the touch, it should be abit hard to start, but nothing too bad. Its ok for the exhaust to smoke a little while the choke is on, but it should be blue smoke (fuel) not black (oil).
Check around the seals on the forks, there should be no oil there.
Try both brakes. The lever should feel firm, not spongy.
Check all the electricals.
Look for dents in the rims
Thats all I can think off right now...
thanks, yeah I'll make sure I her it running and I want to try to make sure my cousin takes it for a spin. The only issue is Idk if I can get him to go considering it's quite a drive and this is a cousin who I'm not really close to but would probably help me out if he can. I'll keep the cold motor start in mind.
Well, motorcyclists generally like to help each other out so you might be surprised. I have helped a few myself, sportbike and HD alike. Its an expectation I have of nearly all riders, intuitively.
If you don't know anything about bikes, take someone. THeer are so many little things you won't realize until you have one a little.
Best advise. Once you buy it get the valves checked, bleed and replace all fluid and filters just to be safe.
