1 - 13 of 13 Posts
Why is it, that out of all the manufature boards, this the best of em all.......is dead..:confused: is that our bikes are just too reliable, too good lookin to improve on..just to fast to upgrade parts..or could it be that we are to tired from those long riding days ??
O.K...on my last post, I asked about a airbox mod. and after lots of reading, and asking questions from other Gixxer owners that have done these mods..I've decided to do the following..
1..change my sprockets, 2 up in the rear, frt. remains stock..switch to a DID X ring chain.
2..Do a airbox mod, which entails opening up the air duct, for increased air flow, which will change to power curve, I already have a K&N filter..
3...The airbox mod requires a jet change to Stage II, and can be tricky...we'll see.
4....Go to a Full System..not sure which one yet..I'm lookin
5..Redegree the cams, setting will be determened
6..Advance ingnition
With all this going on..what I'm looking for is ..more tourqe, and more hp. in the midrange..so do I do a dyno test after each mod..could get expensive..or test it by the seat of my pants???
I will get a Dyno done at some point, at least one before, and after the mods, if I go with a Dyno jet kit, I get a cupon, good for 1 dyno run, but guys I've talked to..say the Yosh jet kit is the way to go...
So...any coments.....pros/cons???
As far as the dyno runs what I would do to cut the cost is make one run before you start you work and one after you are done. The problem is the only thing that matters is the end product and your times from racing / seat of the pants. As far as jet kits I have come to like the Factory jet kits but all of them are very much alike any more with only minor changes with each kit. Just one thing to be aware of the more you changes at once the harder it will be to fine tune the bike. My suggestion is to make one change and test even if it is by the seat of the pants so you have a feel of what is going on. Once you do that you at least have a idea of were you are at before you make your next mod. This way you will get the feel of what is working and what needs to be changed. If you do all the mods at the same time you could end up pulling your hair out trying to figure out what killed your power. Of course if you had unlimited dyno time like I do I would do all the mods on the dyno and every mod would be tested and fine tuned as I was doing it to try to get the best end product with all the mods working together.
If you want to get the most out of your bike, tune it on a dyno.
Give Bamm & Ken a call at BAMM-BAMM High Performance Motorcycle Repair 9032 Artesia Blvd. Bellflower, CA 90706
(562)876-2020
:cool:
suzmcman..good point..I was trying to spend the least, I could get away with..so, I will dyno w/o mods, then do each one, and go by a seat of the pants test:D and continue, till I'm happy, then do a final run on the dyno...thanks
Smeg...that wouldn't be nearly as much fun..not to mention way more $$$$$$...but it's not a bad idea:D
Fatman..I tried their website, but had some probs..you happen to know what they charge for a dyno run??...Thanks
I'll find out, they just set up shop a few months ago. Bamm should have the dyno up and running by now.:cool:
FZR400Tony said:
i thought you were buying a mille?
I am...but I think I'm going to keep my gixxer for a track bike, and I'd like to experiment a bit with trying to get more out of it, not a bunch of hp, but a more well rounded curve..ya know sort of an experimental toy:D
Bamm will be getting their dyno on friday. I'll let you know when its set up. Regular dyno runs will probably cost $30.
for a track bike, you can work on the top-end and sacrifice everything else. that's one of the beauties of a track bike.
if you don't plan on racing, just doing track days, i can hook you up with a 120hp 96 gsx-r750 mill. it has 1/2 weekend on it since replacing the head gasket. the last time it was on the track, it decided it wanted to try figure skating. it missed on the 2 rotations with a twist. :)
as for gearing, i'd ask around before you change it. difference bewteen tracks can be pretty big. and there is nothing worse than being short on your gearing. just 3 teeth off can make for a long, boring, frustrating day (don't ask me how i know).
Discussion Starter #12
Yeah, I'm going to do a bit at a time...I don't want to sink a ton of $$ into it, just make it....FUN for lack of a better word, so thanks for the offer re: the 750...but I'll have to pass:D
Will do, mostly I'll be doing a couple of semi local tracks, and I do know a few guys that ride them..but I'll ask around bout the gearing...thanks:D
And it missed the 2 rotations, with a twist huh...:p
yeah, it was low sided at pocono at about 120. it slid and slid and hit a rut. they said it rotated 2 and a half times. notice, the half. bikes don't like landing head first.
1 - 13 of 13 Posts
