Hi Winfield-
They'll charge about eight to ten dollars to remove the nail, ream the hole, and fill it with a plug soaked in rubber cement. I've run tires repaired in this timeproven manner for thousands of miles without problem by keeping the speed below 65-70 m.p.h. or so.
~ Blue Jays ~
How much do they charge if they have to take the rear wheel off and remount it after they fix the slow leak?
Hi Winfield-
Can you identify the source of the leak? If it's a nail or screw that is still embedded in the tire, just repair it with the plug method described above. If you can't find the cause, it can be repaired with a patch affixed to the inside of the tire. That method will cost a few more dollars since additional work is involved.
Describe the leak and the cause of the leak and we should be able to point you in the correct direction quickly.
~ Blue Jays ~
my method is tubeless tire sealant, works great. I recommend the green ones at Discount Auto and such. I've had the rear blow out at 70 mph, not fun. luckily it wasn't in a turn.
