1 - 2 of 2 Posts
2 questions;
1) is there a headlight kit so i can run both headlights on lows and on hi? i dont like the way it looks with the 1 headlight running with the low beam
2)i just purchased an 04 1000rr all black and dropped 3 inches. im looking for a black 6' extended swing arm. where can i get that?? and what other parts will i need to change along with this?
2 questions;
Its not as simple as modifying the wiring to have both bulbs on at the same time. First note that the bulbs for high beam and low beam are the same. The way the high beam bulb works is that it has a reflector in the headlight casing to direct the light vertically as compared to the low beam. If you modify the wiring to have both lights on at the same time - then nobody will ride in front of you again......
1 - 2 of 2 Posts
