1 - 13 of 13 Posts
OK...so I'm all geared up, bike warmed up, and ready to hit the road. I ease up on the clutch, give it some gas, I'm rolling and BAM! Loud crunch noise...bike stops...feet still up...I go down. I realize I forgot to take off the f*#@ing disk lock. Luckily no one was watching, but managed to ding my crankcase cover (saved my fairings with my leg!). Also have a warped rotor. Bummer deal. I even had one of those wire reminders sitting in my storage compartment. How embarressing and stupid!
Has this ever happened to you?
Let us know how, when and where!
I'm afraid to use my disc lock anytime other then when I cover the bike for the night because I only seem to remember it as part of the routine of taking the cover off. I've forgotten a couple times but luckily I was backing out parking spots at the time so nothing real bad happened. Taught me I didnt want to take the risk tho =>
I've been there done that several times!!!
To decrease the damage potential:
1] ALWAYS use it so you get in a routine
2] park so you have to back up to leave so you don't do what you did and ride forward with it attached (my fender is trashed from backing up with it attached but WTF it's $50 to replace if someday I decide to)
3] get a small round magnet that fits over the lock on the disc lock, when you go to place the disc lock you have to take the magnet off, place the magnet over the ignition key hole. Now to start the bike you have to remove the magnet to start the bike. Big reminder.
4] Along with number 2 place the lock as close to the fender i.e. up top so that you can only back up an inch or two before contact so you don't develope any momentum.
Part of my routine when preparing to ride is the disk lock. I definitely lock the bike when it is parked at home (carport only) So I almost never forget that the bike is locked when I'm home. The other time I lock the bike is when I know I will be inside an establishment for an extended period of time (movies, etc.)
The times I forget the lock has happened very few times. I've forgotten to unlock my helmet from the helmet lock before firing up the motor more.
The guy I bought my lock from recommended that, when backing into a sport, put the rear tire to the curb, put the lock on as close as possible to the caliper in the direction of tire rotation. Push the bike forward till it is in contact with the calipers. That way you can't move the bike at all with it on, 0 momentum means zero damage when you forget about it, you'll just stall.
Great ideas!:thumb: Particularly the magnet. Is genius to strong a word? ;) Just being a smartass. Seriously though I think if they were to follow rule #1 religously the other rules make it near foolproof. Of course I saw a signature on this site a couple of times about creating a better fool so that may be the loophole in this. But I think the magnet idea would make it almost impossible to forget the lock.
Great post!
great ideas
Great ideas so as to not do it again! The two times its happened to me i was facing forward, and the wheel was able to turn 3/4 of the way before stopping...enough to put my feet up. Good reason to get new rotors! Gotta love the magnet idea! Thanks guys
Haven't done it - yet! I have one of the locks that comes with a 24" chain attached. When I use the lock, I either wrap the chain around an immovable object, or I trail the chain out on the ground at a 90 degree angle to the bike, so that you can't help but see it.
I use mine only when I will be away from the bike for more than 30 min., and always use the reminder cable. can't use the brake without being reminded. what I want to get is a throttle/brake lever lock, there is no way to forget about that...
There is a disklock lock that has an alarm in it. It's vibration sinstive so there no way you could ride away with it on unless your deaf. I think it's made by kryptonite. I was looking into them awile back they are like $70
1 - 13 of 13 Posts
