I plan on storing my bike for the winter and to use gas stabilizer....How do i use the stabilizer? Do i add it to the existing gas or do i drain my gas? Can i ride with the stabilizer in the tank or must i drain it? Also any tips with the battery tender is appreciated...
G
Fill the tank with gas, add stabilizer according to the directions on the bottle, go for a ride to get the stabilized gas through the entire system, top off tank (you may need to add a little more stabilizer depending on how much gas you burned while riding). There should be no need to drain the stabilized gas out.
G
Listen to this guy Pete, He really knows what he is talking about when it comes to STORING his bike :D:D:D ..
Pete can also give you tips on decorating your bike for xmas ... They don't get a treeSince the bike is already in the livingroom ...
How long do you need to be storing a bike to worry about using stabilizer? Over winter, I may only use a tank a month, but I haven't ever kept battery on charger or used Sta-Bil or anything. Are you guys talking months?
G
jrm said:
to top
How long would you have to be storing bike w/o riding to bother with stabilizer???
jrm, there's a good article on the deterioration of gasoline somewhere on the internet that will specifically address your question; I'll try to relocate it for you. If I recall correctly, it's something like 3 weeks before gas starts to through the slow process of "going bad". Doesn't sound like you have much to worry about.
I just recently fired up a scooter that had been sitting with a half tank for 5 years! It fired right up and ran great, I couldn't believe it. But thats a rare case. I'd feel safe letting my bike sit 3 months without worring about stabilizer. The most important thing you can do if it's gonna sit is to crack the drains on the carbs and empty the float bowls. A tank full of gas will take a long time to turn in to crap, but the tiny amount in the bowls will gum up and clog your jets fairly quick.
justin
