I've been at a standstill with the rebuilding of my yz250. Couldn't get the primary drive gear nut off. Tried all kinds of setups with no luck. I finally built a jig to hold the motor on it's side and used a cheater to get more leverage. BAM! It came loose. This has been driving me nuts for a few months now.
Now I get to see what my next snag is. Hopefully it'll just be the standard B.S. Can't wait to use the crank separator tool, also. It was sucking oil and it wasn't the rings. Crank seal was bad. Everything is in perfect working order. At least it was when I took it all apart. ;-) HAHAHAHA.
I just want to ass it up on a totally rebuilt 250. I've been without for a whole season. They're building this HUGE overpass by my house and it'd be a friggin sin not to tear it up.
Ha ha, good luck. Nothing ever goes smooth, there are always snags that hold you up. Good luck:)
Just to validate your reply.."nothing ever goes smoothly"...
I split the case, but chipped a tooth off of my shift cam. OUCH, there goes a hundred bux!!!! ;-)...the adapter for my crank insertion tool was the wrong size on the crank end. (wrong thread size)
The GOOD news is, I went to a local machine shop and was able to have a new custom adapter made for 60bux...same price as the factory original which they DON'T make anymore!
So it looks like I can FINALLY send the top end out for boring and sizing for rings..woo hoo!!
THEN.....
As soon as my shift cam comes in, I'll be able to put this bad boy back together.
Maybe, I'll even get to ride it...HAHHAAHHAHA
