My bro in law just picked up his Kawasaki Zepher 750 and rode it home on a 6 hour trip. The bike burns up oil much faster than it should. What could cause this? It seems to be leaking out of the engine also. I assume its some seal that is broken but not sure which one or where to start. It would be a help if someone could point us in the right direction. Thanks:thumb:
R
Guest
OIL?
Sounds like someone has been in the lower end of the bike....good luck:thumb:
Hi Big_Poser:
Can he park the motorcycle with lots of newspaper spread beneath it to determine the source of the oil leaks? That would be a good start.
~ Blue Jays ~
The two most likely areas for a leak from sloppy work are the valve cover from a valve adjustment or a clutch cover from a clutch replacement. Make that three, oil drain gasket or filter.
Next possibility is from a spill and could be either side crankshaft end covers. Clean it up and see what you can find.
I have owned a '93 Zephyr 1100 since new. Make sure the motor has not been over filled with oil, even a little. That will appear as a mysterious oil leak. Try changing the oil and make sure you measure accurately the oil volume you add. Make sure you have the owner's manual or the factory service manual to find out the oil capacity with and without an oil filter change. I am not sure about the 750 but the 1100 has two oil plugs, if you remove only one then the volume of oil you add is slightly less.
The "burning" issue is vague. Could be the rings, that is my best guess with what little information you have provided. Those motors are pretty durable, however, but if someone mistreated it, it won't matter how hardy the motor is, it can still fail.
Any chance that bike has a sight window and level is being checked on the sidestand?
It has a sight window. I don't use it , as it is easier to just carefully measure the oil being put in, other than to confirm the level between oil changes.
