1 - 1 of 1 Posts
I DON'T KNOW WHAT YOU GUYS ARE TALKING ABOUT WITH D&D SYSTEMS. JUST MOUNTED THE SYSTEM AND SYNC'D MY CARBS IN MY CLOSED GARAGE AND IT WASN'T TOO BAD. MAYBE A LITTLE LOUD BUT NOT SOOOO BAD!! :D
Feels a bit weak under 4k from losing the exup, nice hit in the middle and top, feels stronger but my last dyno run said I was running rich and this system should fix that by breathing a bit better. Ran it up to 140 last night to feel out the top end in a couple gears and it's all goooood.
Nice finish on the Carbon can, got the black header which looks pretty good too. Clamps are chrome though and I'm probably gonna paint'em a flat black so they don't stand out with such a contrast. Mounted very easy with perfect clearance at all points once I removed a mid-pipe mounting point that the stock header used (if you have a 97 YZF don't forget to put that nut back on as it looks to be a mounting point between the frame-engine/tranny).
$536 with shipping from Starcycle, D&D was a little slow in getting the pipe to Starcycle since it wasn't on the shelf for my limited production bike but once Starcycle received it they sent it next day ground (it's only like 100 miles from here but I appreciated the effort after the delay by D&D).
1 - 1 of 1 Posts
