well i have decided to swap my sporckets out. i have a few questions and they may be pretty dumb, but here it goes. my main objective is to increase ease of doing wheelies. however i dont really want to loose more than 10-15 mph off my top end. I have a 05' 636. dont know how many teeth need to go count them. Anyways...how many teeth should i increase or decrease forn and rear? After doing some searches i was thinking down one in the front and up 3-5 in rear. But then again i dont really know what i am talking about. I was also hoping to keep the same chain so i know i cant change the sprockets too drastically. One more questoin. I went to a site and not only did i have to choose how many teeth, but pitch as well. Whats the difference between 520, 525, 530? The site has no explanations. PLease help. thanks
Just went out and counted teeth. Stock 15/44. Do you think i could go -1/+2-3 and keep my chain?
First of all, if you are still street riding, then you don't want to change it too drastically. To make it come up easier, you should just go up 2 or 3 in the rear...you will be surprised in the difference. You will have to change your chain as well.
According to http://www.jtsprockets.com you have a 15/ 40 combination with a 520 chain, 108 teeth. The 520 is the chain size, mostly width. A 530 chain is wider, but many of the newer bikes are running 520 or 525 chains...varies per bike.
Double check your rear sprocket, because someone might have changed it already, or my info might not be the most accurate. I know that is the same set up I have on my '03 636.
If you change your sprockets, you can just order a 125 tooth chain and cut it down to what ever size you need...this is one of the easiest changes you will ever do to your bike and you will see the biggest difference.
after doing some searches some websites said i could make minor changes without changing my chain. when i counted i got 15/43, so i had planned on changing to 14/46. I still mostly use my bike for street use so i dont want a drastic change but i could love to get some better low end. my bike is totally stock so i dont have to worry about someone elses mods. thanks for the info
i found a set for $60 to go +2 in rear and -1 front. the company says i dont need a new chain. are they full of crap or what?
