87 FZR 1k and I finally got a chance to spend alittle time together after she sat for a couple of weeks. When I started her up on the the choke the exhaust seemed "muffled". I thought it was maybe from sitting and blow her alittle. The "muffled" and slight "fludder" never went away and can't reach a speed over 75mph, feels like theres no fuel. Drained tank, put fresh gas in just to be sure and same thing. New fuel filter, and petcocks. Is it time for a carb rebuild?
May just need cleaning, one of the jets might have some gunk blocking it. Try spraying carb cleaner
Thanks Vash!
While I'm in there cleaning, might as well check my float levels. I saw in previous post for an EXUP that the floats were to be set at 14mm. Is that correct for mine as well?
Any chance that a mouse may have built a nest in the exhaust? That may explain the muffled exhaust note.
Bike has a supertrapp on it so that is unlikely. Taken carbs off for a complete cleaning and going through. Don't know when it was done last.
Super Moderator
1987
Fuel level: 3.8 - 4.8 mm
Pilot screw: 3.0 turns out
These carbs are pretty sensitive to synchonization. Once you get everything set to baseline, synch, and then make your fine adjustments.
It's good to use a infrared thermometer to help you get the pilots right. Often the inner two carbs will be a need to be a little richer or leaner due to the heat.
