anybody heard of that before....i bought the bike w/ H-4's installed. they are yellow tinted. on my cross country road trip, on the last leg from Amarillo to Ft Worth, boh low beams went out. i had to drive for a couple of hours w/ the high beams...it was at night.
took it too dealer and they would replace w/ factory bulbs again(under warranty)put H-4's back in again???
thanks
'00 VFR800fi
TBR full, high and right
Have you checked your voltage?
I blew my headlight when my regulator went kaput. If it is faulty the voltage can climb way above 12-13 volts to as high as 17-20 this can blow bulbs. (also your battery & important electrical systems)
Put a multimeter across the battery when the bike is running, then rev to see if the voltage spikes.
If it is, you've caught it early.
I was stuck 150kms from home and had to wait for the missus to hire a trailer and get out to me... :) :)
It may be somthing else, but it's worth checking.
0.02
Ross
He who dies with the most toys "wins"
definetely worth checking. VFR's have a problem with smoking Regulator/Rectifiers for some reason. I think that they're narrowed it down to one of the rear spark plug wires inducing voltage into the rectifier. You can read about it for hours on the VFR mailing list.
I haven't heard of any problems with the 2000's as of yet.
Luke
