Does anyone know of any companies that make bodywork for the S2? I kind of want to ditch the square headlight and see if I can get a solo seat setup for mine.
I dunno I think you might be stuck with it. Although with a lil bit of imagination I bet you could fabricate one with one off of the firebolt. I havent seen body work for the s2, I have seen body work for the x1, though it is a bit pricey.:thumb:
Run down to your local junkyard and pick up a cracked S-3 fairing. Cut the round right over the square then trim off the broken mirror mounts. You'll have to relocate the turn signals and mirrors. Mine mounts on a '02M2L on the stock mirror mounts. needed lots of trimming to get it sunk in around the fork legs and get tank clearance. Had some doubts about weight shift and stability but no problems in 20k. It sits several inches higher than the stock S-3. Cost @ $35 for the busted plastic and I think around $80 for the smoked screen. :2cents:
