Well I am 6 feet tall and weigh 187lbs
I have a ninja 250 and I notice that after I spend about 15+ minutes on the bike I start to get a bit of back ache you get when you need to pop your back.
What is this due to riding position, or am I too tall to be on the 250?
I touch the foot pegs with the balls of my feet and hug the gas tank with my knees. I don't put weight on my wrists I try to support myself up using my legs and back.
it feels weird trying to stay up right because the handle bars are too low.
If you are new to riding, I'd suggest it's just your body getting used to things. Some light weight-training, concentrating on your lower back, might alleviate things a bit.
Cookee is right. I have a balance ball & a series of dumb bell weights I use almlost daily along with the addition of a rowing machine again used almost daily, but remember I am an old sod of 67+ yrs of age & ride 6 to 8 + hrs each time I take off with one of my sportbikes up here in the Cdn Rockie Mtn roads. Tack on a lot of knee injuries, broken left hip & such so I have to sort of try & keep myself in shape---well for an old fart of my age.
That means I grip the petrol tanks with my knees & put the abs into work. My back was damaged many yrs ago at home to some comp m/c events. So I can feel a bit of wanting to stretch my back around when riding, BUT worse is getting into my SUV & just driving to the gun range some 15 miles is real agony. I would not dare drive my SUV for an hour.
So a tip is to do a bit of stretching when you are going to ride & when fueling up do the same at the fuel station to where you might stop off at half-way point to when home---stretch a bit & in a while the problems will be gone.
Lastly I am 5'9" plus being around 170 lbs & I had a ball racing, on the circuit, a Yamaha TZR-250 with far more TZ racing parts then most bikes, to also screaming it around the hwys to, to & from work. That small bike was simply a ball to throw around.
