Now that this weather is really starting to suck and it is cold and rainy almost every day, does anyone ride quads or dirt bikes? This is prime weather for some dirt riding. If so where and what do you ride?
Yamaha TW 200. Big a$$ rear tire to get you through the muck, street leagal enables you to ride dirt roads legally.:D I used to ride off road every day when I was a kid, but now-a-days I have no idea of any good places to go without packing up the truck and traking a trip. I would be interested in taking a group ride through the woods with others though.:p
The one I have is blue, but this give you an idea.
Since I have owned several dirt bike I can tell you that this thing goes trough the muck like no other machine I have ever ridden, and you can even ride it on the road. Not very fast, but fast enough in the woods and it will fly on twisty raods due to it's sub 200lb weight.
in my opinion dirt bike offers far greater thrill than ATV so i will say that go for dirt bike especially XT; Yamaha XT660X is a super motard bike from the house of Yamaha. It is a powerful member of XT series. It is titled as “King of the urban jungle” by Yamaha. It delivers dazzling street performance. It has got dynamic and bold looks with saddlebags. Its’ performance is a result of its fine engineering. It is bundled with modern Supermotard technology.
Its single cylinder, four-stroke, fuel-injected, liquid-cooled 660 cc engine generates the power of 35.3 [email protected] 6,000 RPM and the torque of 60 nm @ 5250 RPM. The compression ratio is 10.0:1. The engine is aggressive and ultra responsive at throttle.
Its features are as explained below:
Features:
Engine and transmission:
Displacement: 660 cc
Engine type: Single cylinder, four-stroke, liquid-cooled,
Power: 35.3 [email protected] 6,000 RPM
Torque: 60 nm @ 5250 RPM
Compression ratio: 10.0:1
Bore x stroke: 100.0 x 84.0 mm
Fuel system: Injection
Fuel control: SOHC
Ignition: TCI
Lubrication system: Dry sump
Gearbox: 5-speed
Final drive: Chain
Clutch: Wet, multiple-disc coil spring
Dimensions:
Height: 1,170 mm
Length: 2,175 mm
Width: 860 mm
Seat height: 865 mm
Ground clearance: 205 mm
Wheelbase: 1,490 mm
Brakes and wheels:
Frame type: Steel tube, diamond shaped
Front suspension: Telescopic forks 43mm
Rear suspension: Mono-cross
Tires:
Front: 120/70-R17
Rear: 160/60-R17
Brakes:
Front: Single disc
Rear: Single disc
Physical capacities:
Gross weight: 189 kg
Fuel capacity: 15 L
Color: Red, white, blue
It has advanced diamond shaped steel frame. XT660X is equipped with full-floating 320 mm front disc that delivers incredible stopping power. It ensures the rider’s comfort by its front 43 mm Telescopic forks and swing-arm mono-cross rear suspension. The bike is capable of taking you to new extremes; so you should always use helmets.
Get this bike and spoil yourself!
