1 - 20 of 31 Posts
I want to buy some high-mileage tires, but I've had people tell me not to buy sport-touring tires because less grip could equal danger in the wrong situation, not just in cornering but in braking/swerving as well. Is there any truth to this?
you shouldn't have problems with sport tour tires, they just start to slide/spin a little easyer than full on sport compound, If you aren't riding on a race track @ race speeds you probably will not notice the differance.:2cents:
The grip is pretty good, what you will notice a difference in is how much longer they take to warm up, and how much flatter the profile is, so it takes more effort to lean the bike.
Its not really a bad thing and the amount of effort while noticeable with different tires usually isnt enough to be of concern.
Different tires have different profiles and all "turn in" a bit differently. An hour or two on your new tire though and you will be acclimated to it and wont even notice.
Exactly, the difference is noticable, but not great. Its like going from say a 190 to a 180 tire. Or say from an old tire that had a serios case of a flat center worn on it to a new tire and nice and round...
Touring tires are "flatter" to provide more streight line stability, bigger contact patch, and wear resistance. Racing tires are more "triangular", they provide a greater contact patch leaned over than they do streight. They turn in very quick, and make the bike twitchy, they also wear a flat on them very quickly.
so what are the #'s on the sport tourings vs sport tires? i get about 5k outta my dunlop 208's what can i expect out of a sport touring?
Diablos last me about 2500-3k miles. T46 lasted 8k and had more to go, but I got a nail, and didnt feel like riding with a plug.
Count on at least double what you are getting...
Any opinions on the Michelin Pilot Roads? I've been looking a lot at those. Is the leaned-over grip going to suffer much?
meat, you got 5000 miles out of a set of tires??? i`m thinkin thats waaayyy above what most folks get. i`m a old guy with nill for twisty roads and i got 2800 on my stock gixr bt014`s and that was a new record for me..
Discussion Starter #13
I've gotten 4200 mi. out of my Dunlop BT-012SS tires and I've still got about 1000 mi. left on 'em, maybe more. I may have to toss them early because I've worn such a flat spot from commuting.
We got over 10,000 miles out of the last back tyre on the 250.
Granted it was as square as a Rubik's Cube and was down into the wear bars but, hey, it was still going.
I should add that this tyre was punctured and repaired with a plug with less than 2,000 miles on it and was run up to 100mph (a few times ;) ).
going to try one
I was going to try one of those as I had a brand new pilot power with like 200 miles on it get screw thru it. but just didnt feel comfortable, I've heard a lot of good things on those patch plugs from people though. next time I may have to try it.
Yeah, there's been a lot of discussion on this board as to whether you should plug or replace. Each to their own. :thumb:
(We'd better get back on topic before we get flamed.)
Sanders if your bike came STOCK with Bridgestone BT-012 that is quite a good tyre, regarding the sticky/soft part. I have seen a lot of Yamaha FZ6 bikes with BT-020 (remember the small the number the softer the compound) & that is a far cry from the Bridgestone they put on YZF-600r some yrs back.
The BT-012 is what I put on the FRONT of my 600, Honda 929 & 954 while BT-014 on the rear. Note preference is for more grip at the front & a bit less at the rear. The above two (or should I say "above six") are doing quite well.
By the way Bridgestone class the BT-020 as a Touring tyre, yet those with them on their Yamaha FZ6 bikes are quite pleased with them. So you could go for the BT-020!!!
1 - 20 of 31 Posts
