1 - 14 of 14 Posts
are aftermarket parts like framesliders allowed and whatnot? i signed up for pocono fusa 2.5 on august 14th anyone else going?
yes framesliders are allowed on racetracks. Cages are not allowed.
One of the best purchases for the track are a set of tirewarmers. You will not have to 'waste' your time the first couple of laps getting the tires up to temp. they will give you the most riding time at full speed, and save you from loosing grip and rashing up your bike.
I found an where the guy is selling new sets for $200, but you have to buy 3 sets. If not they are $300 set seperately.
Does anyone know or have used a powerconverter from Checkers or Autozone? I was thinking of buying one to hook up to my lighter, which would power the tirewarmers. I don't want to buy a generator. Or what about this one from Walmart?
http://www.walmart.com/catalog/product.gsp?product_id=3371539
You can use an inverter, but to use the warmers with one requires that you buy one of Expensive inverters, that can cost almost as much as a generator...check out the generators at pep boys...under 350.00 ..sorry, I don't have a link for em..
Re: warming your tires up...If you use the Pirelli Supercorsa's...1 lap should be plenty..:D
can't speak for other brands of tires..although the 208 gpa's take a lap or 2 longer, cuzz they are a med compound as oppsoed the soft pirelli's..;)
how do i tell if my brake pads will pass spec. and i have a crack in my fairing and the tech for reduc says... 8. all body work must be securly fastened and free of breaks. will it pass?
When they state free of cracks, I believe they mean the fairing is so damaged that going down the straightaways at top speed will blow the fragmented fairing onto the track. If you just have a hairline crack, don't worrry about it. If the crack is more severe than that I would put some fiberglass matting and resin on the backside. Search for an old link for repairing bodywork.
There is a groove on your brake pads. When the mating surface of the pad is worn down to the groove it is time to replace the pads. Tech will shine a flashlight into the calipers and look for the same thing that I just explained.
Hammer, so a $40 inverter from walmart that puts out 110 amps can not supply enough power for tirewarmers that require 110 amps or volts, whatever. Please elaborate. :)
It's not the 110..it's the wattage, min. for warmers is something like 1100 watts...and I doubt that 40.00 inverter will supply that much...there was a thread about this very subject on another site....have a look. http://www.gixxer.com/ubbthreads/showflat.php?Cat=0&Number=1636391&an=0&page=0#1636391
sorry to take over you thread Twixt:rolleyes:
Hammer,
I found Tyrsox require 700watts per set. There are plenty of inverters I have found in the 800 to 1000watt range. The problem I think I might have is that they are no-name brands at Pepboys. One is a Vecktor 800 watt for $60 the other is a Vecktor 1000watt for $100. Im unsure if getting these no-name brands is like getting a no-name 3000watt car amplifier that really only puts out 200 watts.
I think I would use a UHaul truck to get my bike to the track. Could I simply plug into the lighter with the truck off, or would I need to let it idle for the 40min it takes to heat the tires?
What about this picture of a Coleman 2000watt on Ebay that sold for $250? Judging by the size of the wires, does it need to hook to the battery instead of thru the lighter??
thanks
sorry, forgot about the pic
Hammer,
thanks
O.K....you didn't say that you were using the "low wattage " Tyrsox...:p Most of the Chickenhawks, and other upper end warmers require more out put, around 100 to 1600 watts...so, you may be o.k...?
I have no idea about the Coleman 2000 watt dealybob..
I personally don't use warmers...with the temps we have at the track...there's no need for em..and even if you had to do 2 laps to warm up your tires...you still get so much track time anyways...2 groups, 20 on, 20 off...
Also, keep in mind that the Coleman in the pic..isn't having to continuesly put out power, as would have to with tire warmers...I have seen guys at the track using inverters, the 2 I saw, it was conected to the battery.. Give a try..and post up how it works for you...:D
thanks for the info. I haven't got any tirewarmers. Im only trying to find the best approach or cheapest approach. I suppose you are right about a soft tire on a hot track would supply enough heat. I only have experience at Portland International Raceway on Dunlop D207Gp's. Of course the NW is a cool climate and track would be also. The problem other riders w/o tirewarmers as well as I had was there are 9 right hand turns and 2 left hand turns. It seemed everyone always went down in turn 3 a left hander, because that side of the tire never got to temp. Does that sound possible?
There is a trackday at Firebird on August 7th. It'll probably be 115 degrees that day, so the track will be hot. I can't seem to locate a cheap set skins, so I will take it easy at the track, and I will only have Michelin Pilotpower street tires. They came on the bike new, but aren't they also a medium-hard compound? Would two warmup laps be enough to trust the tires?
thanks
thanks
207's..?? Dude, get with the "current" times...nobody uses 207's anymore, plus they are old tires, that might be your problem.
Get some 'Fresh" rubber..if you can afford to get em, Pirelli Supercorsa's..soft rear, supersoft front...stick like glue, and warm up REAL fast..:thumb: The down side is, they heat cycle, and if you use em on the street, they wear out rather quickly..
Re: the Pilots..gave up on Michelin a long time ago when they had the regular Pilots..crashed 4 times on those tires cuzz, they 1, took along time to warm up, and 2..when they let go, there's NO warning..I know they've changed, but for me the Supercorsa's just work to good, although my last track day, I used GP208a's in 95 degree heat, and they came up to temp in 2 laps..1.8 mi. course
Re: the PIR situation..yup, espeacilly if it's a tight course, cuzz then it's even harder to get em up to temp..
Dunno if 2 laps would do it, I have no idea how you ride..???
I think the safe bet is...2 laps, and then push it a bit in a slow to med slow turn, if they feel good, then go a tad faster..and I don't know what compound your tires would be, but med is prolly a good guess.
Ever think about buying some "take off's"...usually you can get a good set for 125.00 or less..some with only 2 sprint races on em...which means, there's plenty of life left in them..:thumb:
By the way..I know a guy in Gilbert who races...he could prolly hook you up with some take off's..
The D207's sound dated because they are. I raced for two seasons, 99 and 2000 at PIR, and those were the tires back in the day. I still have 4 sets(used) sitting in my father's storage that I plan to use when these michelins are worn out (for the street).
I guess I should be looking for an extra set of wheels, instead of tirewarmers. I could then leave the Pirelli's, or some other race tire on the rims, instead of wasting them on the street. I will take you up on getting a set of your friend's takeoffs when I score some wheels.
I'll stick with the michelins for this coming trackday (Aug 7th), and take it easy. I just want to get back into picking lines and touching my knees down again. Ill save the fast stuff for when I get some race skins and the wheels/pirelli's.
thanks for helping me sort this out Hammer;)
Trevor
1 - 14 of 14 Posts
