I am looking for a bit of help please...
I recently bought a '92 Kat 600, and the previous owner did not have an owners manual or repair manual. The bike is in great shape and has been very well maintained, and I am hoping to keep it that way! I was hoping someone had a scanned manual with some specs and simple maintainance instructions, which you would be willing to email me.
Any input is appreciated.....
kat600
Hiya!!
I have a 1992 Kat600. I am the original owner and have the original owner's manual. Is there something I can help you with??:):)
Jim
Thanks Jim for the offer.
So far I have been very pleased with my decision to buy this bike. Although it may get a few raspberries from the 'racerboy' types as heavy and slow, it serves my purpose well. I am an ordinary guy who just wants to ride through the mountains on a sunny day and enjoy the road safely. But back to my question...
Just this morning I went to start up my bike, turned the key, and nothing! No dash lights, nothing.. I tried to jump start it but was unsuccessful. (It must have been quite a sight for the neighbours as my wife was helping push in her pj's and running shoes :) ). I was stumped as the bike has started effortlessly every day for the last 3 weeks when it came out of winter hibernation.
I took the battery to the shop and the tech put it on a trickle changer for the night, but felt the battery is probably shot as the water levels were down past the low mark. Whats your guess? Battery? or could it be just a loose connection somewhere? Maybe both? If a battery gets a little low on water is it typically fatal?
A few more quick questions Jim, What is the capacity of the fuel tank? How big is the reserve?
There are dials on the top of the fork tubes with a 1-2-3. What is this, suspension adjustments? What should they be set to?
Thanks Jim, and everyone else for your input....
Hey Derf:
Sorry for the slowness in responding......
The knob on the forks is for rebound adjustment.I have mine set on 2. You can adjust the rear shock's preload and also its rebound too.
The fuel tank is 20.0 liters or 5.3 gallons. The reserve as I recall is one gallon.
There is a circuit breaker located under the seat.If it has tripped a red button will have popped out,push it in to reset.
My original battery lasted 'bout 5 years, but I constantly maintenanced it.Getting a "bit" low on water is not bad but still should be between the upper and lower level marks.Check your connections and make sure they are clean and tight!!:)
You can Email me too if you have other questions!!
Have fun riding!!
Jim
thanks Jim,
As it turned out, the problem was only a loose connection to the battery post. Back on the road having spent $5 and a few 'thank you's' to the tech :)
Rod
YEAH!!
Hey Derf..glad you are back on the road!!:)
The fixes that are cheap and done by oneself are the best!!:D
Where in BC are u located??(Near the border??)
Jim
I am in Cranbrook in South East BC, about 1 hr to the border, and 3 hours to Spokane.
Thanks for all the help with the simple questions, but since I didn't pass 'motorcycle maintenance kindergarten' I am at your and the local shops mercy :)
I have noticed the last few days that the bike has been idling very high, 3-4000 rpm, for at least the first 15 min of a ride, then it kicks down to its normal 1500 range. I started the bike today without using the choke thinking a sticky cable may be the culprit, but it happened again today. :( Any thoughts?
I have been getting about 42 to 44 mpg, is this similar to you?
Thanks, Rod
Hey Derf:
The high idle could be caused by several things:sticking throttle cable,(routine maintenance ya know;gotta be lubed!!)or possibly a vacuum leak.Cable adjustment??Or??
Take this question over to Sage's forum and ask him and see what he may come up with!?!?
Since I have modified the Kat I am not sure till I check it ,as far as the mpg goes,but 50 to 55 mpg was not uncommon when the Kat was stock.I live at sea level and that makes a difference too.
Jim
