B
Guest
i was looking at triumphs website. and notices 2005 triumph daytona 650.
Engine Type Liquid-cooled, DOHC, in-line 4-cylinder
Capacity 646cc
Bore/Stroke 68 x 44.5mm
Compression Ratio 12.85:1
Fuel System Twin-butterfly, multipoint sequential electronic fuel injection with forced air induction
Ignition Digital - inductive type - via electronic engine management system
Transmission Primary Drive Gear
Final Drive X ring chain
Clutch Wet, multi-plate
Gearbox 6-speed
Cycle Parts Frame Aluminium beam perimeter
Swingarm Twin-sided, aluminium alloy
Front Wheel Alloy 3-spoke, 17 x 3.5in
Rear Wheel Alloy 3-spoke, 17 x 5.5in
Front Tyre 120/70 ZR 17
Rear Tyre 180/55 ZR 17
Front Suspension 43mm forks with adjustable preload, compression and rebound damping
Rear Suspension Monoshock with adjustable preload and rebound damping
Front Brakes Twin 308mm floating discs, 4 piston calipers
Rear Brakes Single 220mm disc, single piston caliper
Dimensions Length 2112mm (83.1in)
Width (Handlebars) 712mm (28.0in)
Height 1131mm (44.5in)
Seat Height 815mm (32.1in)
Wheelbase 1390mm (54.7in)
Rake/Trail 24.6 degree/89.1mm
Weight (Dry) 165kg (363lbs)
Performance (Measured at crankshaft to DIN 70020) Maximum Power 114PS (112bhp) at 12,500 rpm
Maximum Torque 68Nm (51ft.lbf) at 11,500 rpm
Colours Tornado Red, Racing Yellow
Seems like the 600 class isnt gonna have too many 600's left in it soon... Kawasaki went to the 636 as well, that pretty much leaves the R6 and the GSXR600 as the only real 600 class bikes in the States
Isn't that the way it goes? The 600's get pumped up.....then the 750's get hot......then everybody wants a 1000.......and then the 1100's come out........then somebody puts out a really cool 600 again. I seem to be having a flash back to the early 90's.......:D
I am still trying to decide what kind of bike I want to buy. I am thinking either a newer 600/750 or a late 90's liter bike. TOO MANY DECISIONS!!!
What? No bike yet?????????
