1 - 1 of 1 Posts
Ok, I am putting on the vfx pivot kit.....I have one problem...the turn signal wires are fed into the turn signals on the stock piece....and then into a rubber connector which the bulb is in...how do I get these turn signal wires fed through so I can take off the stock piece??? Do I need to cut the wires at the rubber connector? someone said ther are plastic connectors like in the front turn signals but I can't seem to locate any from the hole in the tail to the signals itself??? any help would be appreciated! Thanks in advance!
1 - 1 of 1 Posts
